hks cam valve events
HKS 264:
Duration of 264 deg
Duration of 206 deg @ 1mm
Lift of 10.8mm intake / 10.2mm exhaust
Stock valve springs OK
HKS 264 Intake
duration @ 1mm is 206 degrees for 264 intake cam.
opens @ 5 degree btdc
max lift @ 110 degrees atdc
closes @ 31 degree abdc
HKS 264 Exhaust
duration @1mm: 206*
open: 30* bbdc
close: 4* atdc
max lift: 110* atdc
HKS 272:
Duration of 272 deg
Duration of 214 deg @ 1mm
HKS 272 Intake:
Duration @1mm: 214
Opens: 9 degrees BTDC
Closes: 35 degrees ABDC
HKS 272 Exhaust
Duration @1mm: 214
Opens: 34 degrees BBDC
Closes: 8 degrees ATDC
Duration of 264 deg
HKS 264 Intake
HKS 264 Exhaust
duration @1mm: 206*
open: 30* bbdc
close: 4* atdc
max lift: 110* atdc
HKS 272:
Duration of 272 deg
HKS 272 Intake:
Duration @1mm: 214
HKS 272 Exhaust
Duration @1mm: 214
