Turbo Gurus Please Read
Old Apr 26, 2006 | 03:47 PM
Jeffs2006EVOIX's Avatar
I have a friend that is building a turbo Altima, the Turbo he is using is a TDO6-20G, question is the turbo he bought has no oil, or coolant lines. Since it is a TDO6 can he use Mitsubishi Factory Banjo Bolts for his oil and coolant lines to the Trubo? Does anyone know if there is another company that may supply these Banjo Bolts? What would be the best material to use for the lines? Just rubber hose? or possibly lines with stainless braiding? Any input you may have on this would be much appreciated. The only turbo info I know of, its a TDO6 with a 20G compressor, and he needs to know where to get the parts needed to hook up coolant and oil lines. Thanks........
Jeff
Old Apr 26, 2006 | 05:44 PM
MalibuJack's Avatar
The banjo bolts are available through Forced Performance, same thing with the copper crush washers you'll need. Use stainless braided lines if you need flexible lines, since your not sure how they will end up being routed, you don't want it to burn through on the hot side or header or anything else hot enough to melt lines, if at all possible, have him bend up stainless hard lines routed correctly..
Don't use just rubber hose at all..
Forced Performance is the best place to call for information and parts..
Old Apr 26, 2006 | 09:38 PM
Thanks
Thanks MalibuJack for the info I will pass it along to my friend......Thanks
Jeff
okevolutionVIII
Feb 2, 2015 04:07 PM
MR.Maxwell
Jun 28, 2013 08:41 PM
10isace
Nov 25, 2011 08:56 PM
chope045
Lancer Aftermarket Forced Induction Tech
26
Nov 6, 2010 10:02 AM
siony
11
Dec 28, 2008 03:51 PM
