Installed a IX turbo on my VIII
Originally Posted by Anarchy99
I too did this mod i bought an Evo 9-20G for my 05 and i see the same thing later spool but when it hit's it's on with no tune at all after the turbo i'm seeing Trap speed's of 111mph before they were at 107 i want to play around with the Cam gears to see if i can improve spool.
You didnt do the same mod. He installed a straight up 16g IX turbo...you did a 20g IX turbo. Of course its going to spool a little later...its a bigger compressor wheel.
Originally Posted by Stinkapuss
This past week I installed a IX turbo on my VIII. After killing the battery and troubleshooting the leak of the century I'm finally done.
FYI, if anyone is planning on going this route you can get by with the VIII coolant and oil lines but the IX outlet pipe is a must!!!
The spool up is a slower then the VIII turbo but once it hits look out. This car pulls like a motherf**ker!!! Drag times coming soon.
I figured since I have typical bolt-ons like most people this might be of interest.
FYI, if anyone is planning on going this route you can get by with the VIII coolant and oil lines but the IX outlet pipe is a must!!!The spool up is a slower then the VIII turbo but once it hits look out. This car pulls like a motherf**ker!!! Drag times coming soon.
sorry but i haven't really looked into it, let alone even thought about it intill i read this thread but what are the main diff. between the two turbos. well an 05 evo 8 and a new evo 9
thanks
and sorry if its a dump question
thanks
thanks
thanks
you know the ONLY way we will know if the power gains on the IX is the turbo or not? By taking a modified IX and swapping an 05 turbo on it, then we will know for sure! If the car still makes crazy power with the 05 turbo in place then its definitely not the turbo.....
Hopefully someone with a IX here would be willing to volunteer to do this testing
Like I said, lets be serious, or should I say logical. Both Buschur and Dynoflash both said the IX compressor housing is not the reason for the IX making the power it does. If anyone thinks it is, your fooling yourself.
Originally Posted by Speed Element
its been tested by Gruppe-S.. an EVO VIII w/ IX turbo gained about 20-25whp on their dyno..
The only absolute way we are going to see if there is a gain worth doing is if someone with their 10.5-8 turbo does a direct swap for a IX turbo, until then, all of this hype is just that... hype. Even if the IX did add 10whp lets say, is that 10whp worth $500-800?
Originally Posted by Soon2BEVO
It gained power but they also went from a 9.8 to a 10.5/IX turbo and they also used an ECUTEK tune. It was not a straight swap.
but if you are only concerning about brute power, these stock sized turbo and slightly modified turbos are not for you. There are other choices such as 50trim, GT30, GT35R and etc.
i think its worth it. because most of our customers use their evo for daily driving with 91 pump gas here. (gas is very expensive in cali .. $3.99/gal!! every 1hp count!) Not everyone wants to run GT turbo kits w/ gas prices like this..
I will be going to the track this Sunday. I also had the wastegate arm to loose so thats why the spool was a little slower. I tightened it and it now spools at 3400-3500 rpm and kicks hard. I don't care about value to hp. I wanted to try this to see if it works. Maybe it's all in my head but we all will know for sure on Sunday. Another thing to remember is I don't have a custom tune...yet. I'm riding around on a base flash for 272's and I now have 280's and a different turbo.
I probably won't dyno the car because dyno #'s don't mean s**t. The trap will tell me every thing I need to know.
