Installed a IX turbo on my VIII
Old May 5, 2006 | 09:57 PM
  #31
Speed Element's Avatar
Originally Posted by Soon2BEVO
I wouldnt call 10whp for $500-800 a value. If 91 is the problem the real way to deal with it is with alcohol injection which is techincally cheaper.
thats your opinion and you are entitled to that. To some customers, money isn't a issue. w/ alky kit and just want that slight edge when confronted on the streets??
And we know alcohol injection kit will help as well. But what if the customer isn't satisfied w/ just stock 8 turbo and just want a bit more? the power under the curve for the IX turbo is much better compared to the 8. thats fact. And there are customers who want that. .
Old May 5, 2006 | 10:59 PM
  #32
PnutButterWolf's Avatar
i also swapped the evo viii for the ix turbo. no reflash, just ix turbo w/ s-afc tune. gained about 16whp which is what i was looking for (was about 285whp on gruppe-s dyno, now im slight over 300whp. a slight competitive edge over most viii turbo owners. I thought it was worth it in terms of reliability and overall performance that i was looking for.
Old May 5, 2006 | 11:10 PM
  #33
EvoRecordSetter's Avatar
Originally Posted by Anarchy99
I too did this mod i bought an Evo 9-20G for my 05 and i see the same thing later spool but when it hit's it's on with no tune at all after the turbo i'm seeing Trap speed's of 111mph before they were at 107 i want to play around with the Cam gears to see if i can improve spool.
common silly goose, you put a 20g on your car.
this guy put a IX Turbo, a 16G!!!
Old May 6, 2006 | 08:40 AM
  #34
Soon2BEVO's Avatar
Originally Posted by Stinkapuss
I will be going to the track this Sunday. I also had the wastegate arm to loose so thats why the spool was a little slower. I tightened it and it now spools at 3400-3500 rpm and kicks hard. I don't care about value to hp. I wanted to try this to see if it works. Maybe it's all in my head but we all will know for sure on Sunday. Another thing to remember is I don't have a custom tune...yet. I'm riding around on a base flash for 272's and I now have 280's and a different turbo.
I probably won't dyno the car because dyno #'s don't mean s**t. The trap will tell me every thing I need to know.
So you swapped in an IX turbo AND 280s for your 272s?
Old May 6, 2006 | 08:56 AM
  #35
Torre from Va.'s Avatar
That's cool mang.
Old May 6, 2006 | 10:33 AM
  #36
Stinkapuss's Avatar
I had a base flash for 272's and regular bolt ons back in Feb. I added 280's in March and ran 11.9's with the same baseflash. I just added the 9 turbo last week.
I won't get customed tuned until June. I will get the dual stage flash.
Old May 6, 2006 | 10:47 AM
  #37
fromWRXtoEVO's Avatar
I will be eager to find out the results at the track.
SoontobeEvo made a good point, we can't just compare someone runing a 03 Evo8 turbowith a 9.8 swapping with a brand new Evo 9 turbo plus ECUTEK tuning, off course there will be a 25whp gain.
We are talking here about just a turbo swap, perhaps without even tuning at first.
I always had the theory that the Evo 9 are much stronger due to the fact that they outflow the Evo 8 significantly and I never thought that the MIVEC actually does that much of a difference.
There have been a lot of people here comparing spool up times on Evo 8 and Evo 9s and they are very even with the same mods.
I am inclined to say that the Turbo on the Evo 9 is the determine factor on why the Evo 9 is so sucessfull.
On the other hand I am starting to consider the Evo 9 stock turbo to be the most reliable bull**** free turbo. While there is a headache topic about 5 blade, 6 blade,ti-al,white rabbit and all that it looks like the Evo 9 stock turbo will be in most cases a very good candidate for upgrading your turbo, it is reliable, it is cheap and you can find it everywhere.
Carlos
Old May 7, 2006 | 12:57 PM
  #38
Stinkapuss's Avatar
Guess it did something afterall. 11.79 @ 116 mph.
https://www.evolutionm.net/forums/sh...28#post3067528
Old May 8, 2006 | 10:39 AM
  #39
EVIL_EVO_VIII's Avatar
Nice! But you only gained 2 mph, i think the gains on the IX is not from the turbo alone. Look at MOST WANTEDs IX, its insanely fast and he only has a few mods and no cams! Hopefully if you get retuned it will make even more power!
Old May 8, 2006 | 02:59 PM
  #40
dayf's Avatar
If you're running an off the shelf flash for cams and a turbo you don't even have anymore.. a real tune will make a significant difference.
Old May 8, 2006 | 03:17 PM
  #41
Stinkapuss's Avatar
That's what I'm hoping for. I might grab larger injectors and try some afc tuning before my reflash. Another thing is I used my old afc settings from my old turbo. I haven't really tuned it 100% on race gas yet. I might also try a bigger fmic. Not many people running mid 11's with the stock one.
Old May 8, 2006 | 04:33 PM
  #42
i spoke to Chris@ precision today and he told me the IX turbo is definitely a good option for an upgrade and more power can be seen with a tune, so get it tuned so we can see some nice numbers!
Old May 13, 2006 | 10:01 AM
  #43
DCSilvrEvo's Avatar
YO! Are you runnin @ Nopi?
Old May 13, 2006 | 10:16 AM
  #44
DrEvo's Avatar
Awsome run bro, glad to see its paying off, can't wait for some tunning, then we'll really see some good stuff happening!!! Are you still going to CRAPitol or Mason Dixon drag way? Send me a PM next time you go and I'll roll through.
Old May 13, 2006 | 03:33 PM
  #45
Stinkapuss's Avatar
Yep.
I hooked up the wideband and went out and tuned it abit with the afc. My old turbo settings for race gas were pretty far off (rich). I leaned it out and hit the local dyno day today. 375whp/386tq.
I figured when I ran 11.79 I had about 355-365 so I should be able to drop another 1/10 and pick up another mph with my new fuel settings.
