evo 9 turbo on a evo 8
Old May 3, 2006 | 05:20 PM
nefblkevo's Avatar
Originally Posted by frenchy99
I dont want to void the warranty. I know that if I put a evo 9 turbo...it wont void my warranty...
I would have to totally disagree with that. If you put any different turbo on your car betta not go in for warranty work.
Old May 3, 2006 | 05:21 PM
frenchy99's Avatar
Noize, why did you roll your eyes? That didn't help at all. Do you disagree that if this guy UPGRADES HIS TURBO to a IX that it won't give him warranty claim problems?
Frenchy, I can tell you right now that it doesn't matter what that technician says, because he does not make any decisions on warranty claims. You're saying you want to stay as stock as possible, but upgrading your turbo is a pretty big step. That's pretty far from stock. The vast majority of us don't have turbo upgrades.
Btw, the IX compressor housing is way bigger than an VIII. It's also the same visually as doing a 20g-9 upgrade. I would not go through with this plan if you really care about your warranty. That is very dangerous. If you don't really care about the warranty, then doing a stock IX turbo is a pretty good idea. I plan on doing it myself to see if helps with altitude at all...
Warr,
I am in salt lake and that's why I want to try it....because of altitude. I also heard about scott's car...and what it does untuned with this turbo.
Old May 3, 2006 | 05:26 PM
nefblkevo's Avatar
Originally Posted by BoostWhore
so how would they know then if the turbo was modified.... they wouldnt.
From what I have read the ix turbo is almost a direct swap but not exactly, which means a tech should be able to notice. if it means that much to you to keep the warranty you might consider the 65rs tme, which I believe looks almost exactly like the stock turbo and IS a direct bolt on replacement.
Old May 3, 2006 | 05:27 PM
Warrtalon's Avatar
Yes, and I agree that it's a good turbo, but Scott and the rest of us also know that the majority of his current gains can be attributed to the o2 housing and 10.5 hotside. Hopefully, after tuning from Al, Scott will see even more gains, because then it means it may be a useful upgrade for us. I'm particularly interested in seeing how well it holds boost by 7k rpm, because my stocker won't hold boost at all past 5500rpm. The IX isn't that much different, so I'm not convinced it will do any better...
Old May 3, 2006 | 10:19 PM
frenchy99's Avatar
Thumbs up
yeah we just have to see....in my opinion is that we will see good numbers....
Old May 4, 2006 | 01:33 PM
Stinkapuss's Avatar
I'm going to the track with my 9 turbo this weekend. We'll see if it makes any difference.
Old May 4, 2006 | 09:24 PM
trinydex's Avatar
are you sure the typical untrained eye can catch it? you sound like you're going to a dealer that knows what they're doin... are you? i don't know of any of those.
to answer the poster's question... the only thing we have right now for the community to see is the gruppe s dyno test, search it.
Old May 4, 2006 | 09:26 PM
Warrtalon's Avatar
They usually don't know much, but the 9 compressor housing is much larger than the 8's, and it's very noticable to the naked eye.
Old May 4, 2006 | 09:40 PM
kimletrim's Avatar
Registered User
Yes, and I agree that it's a good turbo, but Scott and the rest of us also know that the majority of his current gains can be attributed to the o2 housing and 10.5 hotside. The IX isn't that much different, so I'm not convinced it will do any better...
So what you say is pure speculation. You do not KNOW, you only believe that the gains are where you say they are. Stop guessing. Until we see the dyno charts for just the 02 housing and 10.5 hotside compared to turbo upgrade alone, your statements are inaccurate.
Old May 4, 2006 | 09:42 PM
Warrtalon's Avatar
What's that all about, kimletrim? We have already seen these gains from an o2 housing and 10.5 hotside many times. It's more likely that's where the gains came from rather than the IX. Go argue with Dave Buschur on it if you want - don't single me out.
Old May 5, 2006 | 11:06 AM
High_PSI's Avatar
Not trying to argue even Al had stated that the IX turbo would give significant gains, you yourself were asking for a IX turbo so you must believe that it gives gains. IDK how much but there is gains.
