Read this if concerned about spinning a Rod Bearing.
Old May 4, 2006 | 02:56 PM
naucrx's Avatar
Originally Posted by tbplayer45
I check it everytime I put in gas. It's a good habit to get into.
Great habit to get into!
I will usually check the Evo every other tank, but my Civic every tank because that thing leaks oil like crazy.
smokedmustang's Avatar
Originally Posted by Jim_Patterson
I always check it after some drag racing, or hard driving.
Where were you when I needed this advice?? 3 runs, 3 quarts?
Old May 4, 2006 | 03:01 PM
It looks like all you "oil checkers" WONT have the problem I had then!!
Old May 4, 2006 | 03:30 PM
slvrevo's Avatar
ya know, i had an experience where I dyno tuned my car. checked oil before and after the dyno runs and there was no loss of oil. i drove around town, freeway and streets for about 300 mi. and i was 1 quart low, just below the lower mark on the stick. i still don't know where that quart went. definately good advice to check the oil. my car only has 3k mi. and did not loose oil at all till this happened. i've driven it some 600-700 mi. since and i haven't lost a drop of oil. real strange...
slvrevo
Old May 4, 2006 | 05:33 PM
althemean's Avatar
dont feel bad man. My car let go and I am very meticulous with the maintenance. Like I said in my post with my carcked piston pics. These are high strung turbocharged cars. We race them and drive them hard. The motor will give out at some point. Its not a question of if it will. But when it will.
Some get luckier than others. 66k is great milage for your mods. I planned on overhauling my motor at 40k. I figured I would make it that far. I cant rule out that the AEM had a large part in the motor going out sooner than expected. It wasnt so much the tune as it was the extra demand placed on the stock fuel system after installing the AEM. Live and learn.
Old May 4, 2006 | 10:29 PM
Evo_SpeedKing's Avatar
so Kev, what are you going to do with that TME 6.5 turbo now?
Old May 4, 2006 | 10:33 PM
Derek888's Avatar
Originally Posted by KOEvo
SBR 2.1
10.5k RPM's here you come!
god dam...
Old May 4, 2006 | 10:40 PM
2GDSM's Avatar
Cmon....you cant lose 3 quarts in 3 1/4 miles passes. You must've let some idiot change your oil and they probably didnt refill it all of the way. If I had a dollar for every time that's happened to me i'd have about 7 bux. Sorry to hear about the bearing. Goodluck with the rebuild.
Old May 5, 2006 | 02:26 AM
I didn't think so, "someone" probably got distracted in the middle of changing the fluid, and didn't fill it all the way up!! Its hard to tell, I will do it myself now!
Old May 5, 2006 | 02:28 AM
Originally Posted by Derek888
god dam...
Hey Derek!! no cussing on my god dam threads . I would like to see this motor in my engine bay, and will let you know how it does!!! Now if only I had your "secret" hideaway license plate deal!
Old May 5, 2006 | 03:07 AM
DanJ's Avatar
Im not sure if anybody else has noticed this but my oil get old very quick it seems like.
I change the oil on all my cars every 3k, on my eclipse the oil would just be starting to get a darker shade of brown, on the evo after about 2k miles I notice it always looks like it needs changed. Both mobil 1 syn.
That's normal, I believe it's because the evo has a lot of oil that doesn't drain as easily such as the oil cooler. So it mixes with the clean oil a bit quicker. The color of the oil doesn't matter too much it's more if it still has some viscocity.
Old May 5, 2006 | 07:15 AM
'ringmeister's Avatar
so somebody other than you changed the oil? i gotta say, you are much more rational about it than i would be . i'd be pi$$ed to say the least. if you are gonna start changing your own oil, look into the the kit that griots garage sells. it's a tube that you stick down the dipsatick tube attached to a tank with a built in syphon. you give it a few pumps, go away for an hr, and it sucks the sump dry. no need to jack the car up (except to change the filte).
Old May 5, 2006 | 07:43 AM
Great advice!! I just got one of their catalogs, have to look that piece up!! Thanks!
Old May 5, 2006 | 07:44 AM
Eclipsed Evo's Avatar
Same here.
Old May 5, 2006 | 07:47 AM
WhiteEvo05's Avatar
That's a good idea because i stand around with my thumb in my azz the whole time.
Wow, an exhibitionist with a smelly thumb...
