Read this if concerned about spinning a Rod Bearing.
Old May 4, 2006 | 11:59 AM
smokedmustang's Avatar
Unhappy Read this if concerned about spinning a Rod Bearing.
I have 66K miles on my car, modified since 2K miles on it. I have done spirited runs, autocrosses and permanent road courses. The car held up fine. I changed the oil on my car 2 weeks ago, and did 3 passes at the drags. I then drove it 300 miles since.
I never checked my oil in that 500 mile time frame since I took the car to the drags. It is either I lost 3 quarts in that amount of time, or the oil wasn't put in from my oil change. Either way, the oil was TOO LOW to keep the rod-bearings "healthy". I would make these recommendations to YOU, to save you the time and trouble I will be going thru! I spun a bearing and need a NEW MOTOR!!
1. Check your oil OFTEN!!
2. check your oil BEFORE AND AFTER you do the "strip"
Again, I had 66K miles on my car of hard-driving, but in the last 500, there were 3 passes on the drag-strip. those passes either sucked 3 quarts of oil out of the car or something.
Your dipstick is your friend, look at it!! (that sounds kinda perverted ) Good luck, and hope I helped someone out!
Old May 4, 2006 | 12:02 PM
EVIL_EVO_VIII's Avatar
Thanks for the advice! Good luck with the car bud
Old May 4, 2006 | 12:03 PM
IEXCELR8's Avatar
It is a simple thing to do, I check mine every day when I pull it in the garage. Sounds **** but I want to keep an eye on it.
Good post and heed his advice!!
Old May 4, 2006 | 12:04 PM
KOEvo's Avatar
SBR 2.1
10.5k RPM's here you come!
Old May 4, 2006 | 12:14 PM
tbplayer45's Avatar
I check it everytime I put in gas. It's a good habit to get into.
Old May 4, 2006 | 12:15 PM
KOEvo's Avatar
That's a good idea because i stand around with my thumb in my azz the whole time.
Old May 4, 2006 | 12:18 PM
meanmud's Avatar
Great advice
Sorry for your loss
Old May 4, 2006 | 12:19 PM
Mulholland0132's Avatar
Good luck with the rebuild.
Old May 4, 2006 | 01:50 PM
CFaber's Avatar
Same here! My car, with over 300whp, has never burned a drop of oil yet I still check it everyday.
Old May 4, 2006 | 02:00 PM
tbplayer45's Avatar
lol
Old May 4, 2006 | 02:15 PM
I know it sounds stupid, but it is an easy habit to heed to, and you wont have to buy a NEW MOTOR!! keep em on the road, keep an eye on the oil!!my 2c, or rather, my 5K!!
Old May 4, 2006 | 02:31 PM
Rnm's Avatar
Rnm
I check my oil every other day, yeah, I am that ****.
Old May 4, 2006 | 02:33 PM
Tpayne84's Avatar
What are your plans for your new motor?
sorry to hear about your engine also.
Old May 4, 2006 | 02:35 PM
Jim_Patterson's Avatar
I always check it after some drag racing, or hard driving.
Old May 4, 2006 | 02:37 PM
Im not sure if anybody else has noticed this but my oil get old very quick it seems like.
I change the oil on all my cars every 3k, on my eclipse the oil would just be starting to get a darker shade of brown, on the evo after about 2k miles I notice it always looks like it needs changed. Both mobil 1 syn.
