Stock Clutch?????
Old May 6, 2006 | 12:25 AM
evo ippo's Avatar
Stock Clutch?????
How long do these things usually last? i know it all depends on the driver i don't really drive it hard, never really drop the clutch out of the hole but on ocassion i open her up on the freeway and stuff. i have about 2500 miles and getting dyno tune May 14 just little worried.
Old May 6, 2006 | 12:49 AM
Evo Girlie's Avatar
As long as u don't launch the car and drive it pretty normal each day u should be able to have it for a while i'm guessing 20k + miles depending on how many times u go wild with it =). I know a guy that had stock clutch for 36k miles and he launched it a few times. Once u get ur tune u may be more tempted to really see what the car can do so it is all on you =)
Old May 6, 2006 | 12:59 AM
RenoEvo's Avatar
It will last a long time if you're at stock power levels and don't launch. Considering you know how to drive.
Old May 6, 2006 | 05:37 AM
Ph3n1x's Avatar
No launch + good driving skill = long lasting clutch in most cases.
Id say with Very conservative driving youd get 30k out of it.
Old May 6, 2006 | 05:41 AM
dave9172's Avatar
im at 30k now w/ no issues, except stupid 4th to 5th gear grind at 5000rpm and above.
Old May 6, 2006 | 05:45 AM
Evoryder's Avatar
my clutch started slipping bad at 22k w/ 2 trips to a drag strip and plenty of back road launching
Old May 6, 2006 | 06:06 AM
dubbleugly01's Avatar
45K miles out of the stocker with hard street driving, and only a few launches. It was still holding fine when I pulled it out. I've got all the basic bolt on's plus cams and TME turbo.
Old May 6, 2006 | 06:21 AM
ohio-evo's Avatar
The big factor here is driver. Don't ride the clutch and don't sit a lights with the clutch pressed in the whole time. Take care of it and it will take care of you. I had 26K on my 03 when I traded it in and it felt like new. Auto crossed a few times and went to the strip maybe 10 time. Good luck at the DYNO.
Old May 6, 2006 | 06:31 AM
mac_05evo's Avatar
I got about 22000 on my stocker with several trips to the drag strip and some occasional hard driving..
Old May 6, 2006 | 07:00 AM
GroundChuck's Avatar
If you truely drive like you mentioned below, you should get MANY miles out of it. I have 60K miles on mine. I drive like you mentioned below. In addition I have been to Gingerman (track) three times. Also there are two times (I recall them vividly) when I really burnt the crap out of the clutch (being a dumb ****). Mine still drives like a champ.
Old May 6, 2006 | 08:38 AM
Soon2BEVO's Avatar
Completely dependent upon driver, # of launches and power your car has. Some people with less power than me ruin it in 5k miles. Im at just about 50k on the stocker.
Old May 6, 2006 | 08:40 AM
Ultimate CC's Avatar
If you launch right it really doesn't hurt it that much....
Old May 6, 2006 | 08:43 AM
Makos1610's Avatar
mine last for 13k miles but i did lot of drag racing and launching and also some autocross events so it's all depends how you're gonna drive it
Old May 6, 2006 | 09:06 AM
djmikeymike's Avatar
32K miles and i drive hard..... no launchs it feels like new
Old May 6, 2006 | 09:15 AM
denolloyd's Avatar
I have 53000 miles and a 35R. My car makes close to 500 whp. Im still on the stock clutch. It holds very well. If I launch however, it slips a bit. The stock clutch isnt as bad as many think...
