PCV system theory and Oil catch cans.
Old Sep 7, 2007 | 01:20 AM
  #181
JT-KGY's Avatar
How much oil do u guys collect on the can sitting in front of the firewall but
behind the engine.
I'm getting this much after about 150 miles...
But after a while... the tube will stop collecting oil until I empty it. ??
Old Sep 7, 2007 | 07:29 AM
  #182
cfdfireman1's Avatar
What is that thing and how big is it?
Old Jan 8, 2008 | 11:50 PM
  #183
taylor8's Avatar
I Have attached pic of the catch can I wish to fit.
The former owner had it pied up as you see in the attached picture.
Is it ok to plug the inlet manifold, if so what size of plug??
Old Jan 9, 2008 | 02:40 AM
  #184
taylor8's Avatar
bttt
Old Jan 9, 2008 | 08:33 AM
  #185
taylor8's Avatar
anyone
Old Jan 9, 2008 | 12:28 PM
  #186
JT-KGY's Avatar
dont think u should plug anything...
Old Jan 9, 2008 | 12:58 PM
  #187
Are you saying the hole in the intake manifold is open?
Old Jan 12, 2008 | 07:47 PM
  #188
gsbabyboy10!'s Avatar
So I have the new style Greddy catch can. Connected it from breather valve cover side to the catch can, then to the air intake. Im having problem with my idle (fluctuates really badly, sometimes stall) when connected back to the air intake. yet id idles fine when vented to the atmosphere.
Anyone have any idea wat could be wrong here. Its really bugging me. Should I jus let it vent to the atmosphere?
I dont an evo btw. I have a turboed eclipse. With greddy emanage. Was also wondering if it could be the tune of the emanage thats causing all the idle prob when i connect it.
Any help is greatly appreciated.
Old Jan 12, 2008 | 08:08 PM
  #189
lemmonhead's Avatar
that is about how much i get also.
behind the engine.
Old Jan 12, 2008 | 11:19 PM
  #190
JT-KGY's Avatar
Thanks
Old Jan 19, 2008 | 02:29 PM
  #191
WADADLIG_OZ's Avatar
subscribed
Old Jan 11, 2009 | 08:50 PM
  #192
Protostar1's Avatar
Okay... this is a stupid question but I have been sitting on EvoM for 2 hours now and research isnt my thing. Can someone simply point out the two points that the second can from the DC3 sits between? As in, where is the PCV and intake manifold lines on the Evo?? I get the breather to the air filter, but I am not able to figure out the other two points. Fireman YGPM
Old Jan 13, 2009 | 10:08 PM
  #193
rodman's Avatar
Standing in front of the engine, find the oil cap. Right behind it on the back side of the valve cover you will and or should find the PCV valve. The hose runs from there to the intake mani about 6-8 inches long. You want to remove that hose and add the new hose (as short as you can) going from the PCV valve to the top of the DC3 and the other hose from the side of the DC3 to the intake mani. The flow and or vacume air go's in the direction from the PCV to the mani and will not flow the opposite way unlass the PCV valve is faulty.
Old Feb 2, 2009 | 02:10 AM
  #194
huevosrancheros's Avatar
Ok , finally
This is the way I'm hooking up my catch can. PCV to catch can, catch can to intake manifold.
Old Mar 19, 2009 | 10:24 AM
  #195
mikevoSE's Avatar
Originally Posted by Fourdoor
link to a cool catch can
OK, here is a diagram of a properly configured dual catch can setup. Each can should have some form of filter media in it to help condence out the nasty crap you are trying to capture.... an open can works, but not nearly as well.
Keith
Is this the same on the Evo X?
