Very interesting observation on Works 3" 02 housing
Originally Posted by Wangracing
I have the works DP but am considering adding a splitter to it match up to the existing divide in the exhaust housing to keep the wastegate gases separate slightly longer. This was always a good mod on the WRX STI which is my background. Very keen to see the results of this test with the full open mouth DP.
my .2c
Carlos
Wangracing,
The dividing wall on the Works housing is a not a feasible project in my opinion. I think you will compromise relibility by trying to weld a dividing wall.
After all I found out that perhaps the hotside on the Evo turbo actually has a dividing wall already..
Carlos
Carlos
Originally Posted by trinydex
iunno that woulda been the interesting part. welding cast iron isn't such a big deal... turbonetics used to weld elbows on their compressor housings for the 2g dsm trubos.
arent their compressor housings aluminium??
Yes the exhaust housing does have a small dividing wall. But it is very small. I think there would be some benefit in extending it into the o2 housing. From pictures I have seen, the factory 02 housing does have a splitter in it rather than full open mouth.
Yes the WRX/STI from factory did have a flat plate in front of the wastegate and only had a good opening in front of the turbine exit point. But, we did test a full open mouth dump pipe and one with a "splitter" as we called them and there were measureable improvements in spoolup performance of thr turbo with the splitter. ie. The turbos consistently produced more boost at a lower rpm.
Regardless and back on topic, very much looking forward to seeing the 02 housing shootout!!
Originally Posted by fromWRXtoEVO
Wangracing,
Carlos
Carlos
here is the link to the test that db did 2 years ago. https://www.evolutionm.net/forums/sh...d.php?t=208826
FS[West]: Invidia 02 Housing w/gasket
Spoolin4g63
15
Oct 30, 2016 10:47 AM
jspecteggy
13
Sep 3, 2014 07:27 AM
tmd1183
Oct 24, 2013 10:56 AM
P!N-EVOVIII
Mar 14, 2010 10:50 AM
Call David B. and ask him to pull out his ancient archives.
