cleaning MAF....
Old Aug 22, 2010 | 11:06 PM
hang187's Avatar
I also use that CRC product. Like the post says, the idle does seems smoother.
Originally Posted by spudlus
The CRC product is good. I clean my MAF every couple of months or when I clean my filter. Typically the idle is smoother. I would imagine it also helps throughout the rev range.
Old Aug 23, 2010 | 12:21 AM
NorCalEvo415's Avatar
How often do you guys clean your MAF?
Old Aug 23, 2010 | 12:56 AM
4g63Moon's Avatar
Go to autozone or checkers and pick the a maf cleaning spray. I have one and it works perfect
Old Aug 23, 2010 | 04:47 AM
gsrboi80's Avatar
Clean mine every oil change. Gives me something to do while the oils draining
Oh and agreed. I only use the Mass Airflow cleaner from CRC
Old Apr 13, 2011 | 07:29 AM
victorr's Avatar
On this link it sys not to use on Mitsus:
http://www.crcindustries.com/faxdocs...on/st05110.pdf
So safe or not?
Old Apr 13, 2011 | 07:37 AM
AlwaysinBoost's Avatar
the CRC stuff is not supposed to be used on Karmen Vortex sensors like the ones found in our cars... it says so right on the bottle. USE AT YOUR OWN RISK!
Old Apr 13, 2011 | 07:39 AM
spdngdragon's Avatar
So safe or not?
subscribed for info...
Old Apr 13, 2011 | 07:41 AM
Siyah's Avatar
So safe or not?
Good find... now I am nervous. Somebody know ?
Old Apr 13, 2011 | 07:43 AM
gsrboi80's Avatar
Used for over 130k as have countless others can't see any downside unless you stick the nozzle in there and break the little resistor wire
You'd have to be about an idiot to do that. Wonder what their reasoning is?? Likely a CYA thing if someone breaks the little wire
Old Apr 13, 2011 | 07:46 AM
06MREvo's Avatar
^^^What he said...
Old Apr 13, 2011 | 07:48 AM
evo1008's Avatar
maf cleaner
i cleaned mine with he special one just for maf and started to work again
Old Apr 13, 2011 | 08:01 AM
I don't know what their reasoning is for not recommending it on KV equiped vehicles, but I do know they are a local company (to me) and they do all their vehicle testing at the shop I go to (RT/Tuning). I've seem them at work (back to back testing on cars) and know the dyno results they report on the can are real gains they've measured on the dyno. To me that gives them creditability. So I have to believe if they say not to use in on our cars there is a reason behind it.
I don't care what anyone else does to their cars, or how many times they've used it, but if the manufacture specifically says NOT to use in on a certain vehicle I'm going to listen to them.
Old Apr 13, 2011 | 08:24 AM
andrewzaragoza's Avatar
^what do you use/recommend to clean the maf then?
Old Apr 13, 2011 | 08:34 AM
gsrboi80's Avatar
CRC Maf Cleaner .
I am going to try to send an email to the company within the next couple of days to get their reasoning behind no using it on a KV Maf equipped car.
My guess is it has absolutely nothing to do with the chemicals in the can and more to do with covering their *** if you hold the can up to the little resistor wire and blow it clean out the other side
Old Apr 13, 2011 | 08:38 AM
shifthard's Avatar
Yea go with the crc cleaner.
