Ouch! 10.93 @123 EVO 9 in PR
Ggrey, that's with a 75shot, which gives anywhere from 75-100whp extra. Don't look at the ET; look at the mph. He basically took a 114-116mph trapping IX and added a sizable shot of N2O. This also had to include some nasty driving, since it takes 124mph minimum to hit 10.9s usually. This must have been a high 1.4 or low 1.5 60', which is amazing if he doesn't have a strong clutch upgrade and fatter tires.
Heard the news last night. Great job. He ran 11.1 just a couple days ago and yesterday 10.93. Amazing for such simple setup. I'm pretty sure he had run a high 11 off the bottle.
Originally Posted by Jack @ EvoStore
As I understood it, the car had still not been re-flashed and had to run the external setup to avoid boost cut. Once the car gets some better engine management, it should be even more serious.
That might be the case, but i would bet it is just to control the turbo with the nitrous.. The nitrous will make ALOT more exhaust flow.. probably too much for the stock wastegate.
-Zach
