20g9 or 6.5 rs tme for Alky?
Old May 21, 2006 | 06:21 PM
BMan's Avatar
That's why the White Rabbit has the 5 blade set for more air space. Oops, I brought another one up.
Old May 21, 2006 | 06:31 PM
IntegxX's Avatar
I can get a brand new white rabbit for really cheap... so would the white rabbit show good gains over the tme and 20g... Boosting over 24 psi that is.
Old May 21, 2006 | 07:46 PM
WillEatUrSTi's Avatar
If you can get one for cheap I'd say go for it.
Old May 21, 2006 | 09:35 PM
High_PSI's Avatar
Originally Posted by NIevo
The problem is your just looking at peak #'s, not the overall powerband. The 20G holds its power alot longer than a stock or 6.5TME turbo. Theres a graph on here somewhere showing it holding peak power the whole graph (once it spooled of course). Sure it might have only gained 20whp or so but elswhere it gained huge, 50+ if I remember right.
I am looking at the power under the Curve. The TME stretches it left a little and gives up nothing on the top end. The 20G gives you lag and still falls off up top. I am not sure what Turbo Trixx uses in their 20G but it certainly makes more power then the Buschur. I would like to see that graph but I hope it is not on the Buschur car, I am looking for mostly a Stage 4 car with then an addition of the 20G. I would imagine that it makes more power, it would have to, but the TME just gives SO much torque and really that much better throttle response. I have also yet to see a trap speed with the Buschur 20G that is better then what you can get with a stock or a TME. That is my biggest issue.
dbdude
Mar 18, 2008 02:47 PM
EvolutionBoy67
Mar 6, 2007 04:12 AM
BlouchTurbo
17
Feb 18, 2007 08:21 PM
NocturnalEVO
42
Feb 8, 2006 11:20 AM
inariv5573
May 13, 2005 06:48 AM
