Moan/whine evo 8 03 tcase/tranny help
Old May 22, 2006 | 09:06 AM
  #31
sairaag's Avatar
Yeah I bought it for 44 shipped. So I hope I get it soon.
Old May 22, 2006 | 06:09 PM
  #32
sairaag's Avatar
so does anybody know how long the moan or whine can go before it craps out? i stoped driving my car until I get my diaqueen fluid and change the oil and see if I have metal chisp on my tcase.
Old May 22, 2006 | 08:22 PM
  #33
FastCoEVO's Avatar
mine makes a whining noise. but it drives perfect. Its got just under 40k on it and its whined since I have owned it 30k.
Old May 22, 2006 | 08:38 PM
  #34
expl0d's Avatar
I had this same problem, took it to John Shepard along with a new Tcase and my problem was solved :x
call john up and ask, he's dealt with it before he'll tell you straight up what the problem is....
www.shepracing.com
and if you dont know who john shepard is.... well he's a god.
Old May 22, 2006 | 08:51 PM
  #35
BMan's Avatar
Originally Posted by sairaag
Shot at 9k? Thats hard to believce since I don't even beat on my car.
When I had my driveline service done at a Mitsu dealer, the transfer case was shot in 1000 miles, they replaced it and in 600 miles it started to whine. When I drained it the oil that came out was as thin as engine oil. They don't use the correct lube because it costs too much.
As I hear it, the Diaqueen has an 'anti-shock' additive that keeps the lube in place under extreme load.
I had my tranny and tc rebuilt by TurboTrix Racing and had them send the gears to Armoloy for coating. It cost a few $$$ but it is smooth and quiet and my fear faces are now 72c rockwell.
Old May 23, 2006 | 09:16 AM
  #36
sairaag's Avatar
has anybody tried a law suit against the dealership for putting the wrong oil in the tcase? Because my oil was very thin and I am pist. I saved my oil in a bottle and I am going to see what i can do about this.
Old May 23, 2006 | 11:15 AM
  #37
RalliArtEvoVIII's Avatar
its ur t-case. period had to replace mine twice before is old my 03. Never will i get any evo other than an 05 or 06
Old May 23, 2006 | 12:49 PM
  #38
sairaag's Avatar
yeah but if you have one properly built by shep or teamrip it should not happend again since they make them stronger than normal.
Old May 23, 2006 | 01:22 PM
  #39
gaulrich2003's Avatar
Does it sound like radio interference or something? The further u press the gas peddle the louder it gets but it never becomes loud enough that u can hear it over the radio?
Old May 23, 2006 | 02:57 PM
  #40
sairaag's Avatar
Yes, but sometimes the faster I go the noise goes away or you hear it very little.
Old May 24, 2006 | 05:26 AM
  #41
gsujeff55's Avatar
i had my tranny worked on by mitsu and when they filled the t-case up after re-install they used tranny fluid. t-case was whining within a thousand miles....so they replaced it. now this one is whining, but its been about 10k miles.....just gonna get the mfer built and call it a day
Old May 24, 2006 | 08:49 PM
  #42
boostedwrx's Avatar
dont worry about it. Drive it until it stops then tow it to the dealer. They may not replace the TC and tranny every time. I never had any luck with any of my tc's on the old evo.
Old May 25, 2006 | 04:34 PM
  #43
sairaag's Avatar
hard to drop it off at the dealer when you got a full exhaust and 280 hks and al's ecu tune. I just put diequeen oil in today and didn't help at all. I do have a question can the transmission whine? it just fine but I just want to make sure is not the tranny nothing grinds and it doesn't jam shifting.
Old May 25, 2006 | 05:04 PM
  #44
EVIL_EVO_VIII's Avatar
when the tc whines is bc 99% of the time the wrong fluid was put in causing damage to the ring and pinions... It only takes one time for it to get damaged,this is why i dont take mine to the dealer to get it changed
Old May 25, 2006 | 05:13 PM
  #45
sairaag's Avatar
yeah I know I change the oil and the old oil came out like water.
