GSC Power-Division Evo 1-3 Cam Release Dyno Inside!!!!!
We are proud to release the latest in our cam line. The GSC DSM/EVO 1-3 cams, we were very excited by the power these made when compared to the competition. Listed below are the specs for the cams and the part numbers. If any one has any questions please don’t hesitate to ask.
DSM Cams are made from new high nickel content iron alloy billet Cores. No Regrinds here! We are using the same Polished Lobes on our DSM/EVO1-3 Cams as we use on our EVO 8 Cams. The Polishing process eliminates break-in and tolerances are with in .0001.
Specs
Peak Lift is 10.44 in and 9.91mm exhaust
Total Duration is 268
Duration from 1mm to 1mm is 204
Total Duration is 281
Duration from 1mm to 1mm is 213
Applications
EAGLE Talon TSI, TSI AWD 1989-1999 Turbo
MITSUBISHI Eclipse GST, GSX, Spyder GST 1989-1999
MITSUBISHI Galant VR-4 1990-1993 Turbo
PLYMOUTH Laser RS 1989-1994 Turbo
MITSUBISHI Lancer Evolution 1-3 1993-1996
Part Numbers:
6020 - 268 intake
6021 – 268 Exhaust
6022 – 281 Intake
6023 – 281 Exhaust
Here is a Test of the Cams in action. The test car was a 95 Eclipse using the 281 intake and exhast. 16G turbo, full exhaust. with a GM 3" MAF and a SBR BIG Front Mount.
With a Sold 52whp increase at 4k rpms and a full 33whp increase across the topend. the Boost was set for both runs at 22psi and tappered back to 20psi. Air Fuel was a consitant 11.7 for both setups.
Specs
Applications
Part Numbers:
6020 - 268 intake
6021 – 268 Exhaust
6022 – 281 Intake
6023 – 281 Exhaust
I was pretty impressed with them. the car is now getting a 61mm turbo and a fuel system and AEM so we should see some big numbers. its also a Stock 7bolt bottom end so the owner and i are thinking stroker next!
Originally Posted by trinydex
cam gear settings or lobe center lines? seems there was a delay in spool... seems like one of the popular top end cam gear settings.
Looks like they make good power
liteSPEC
217
Feb 12, 2013 02:37 PM
ImportUpgrade
For Sale - Part Outs
75
Feb 7, 2007 10:45 AM
Chris@nolimitmotors
Feb 6, 2006 12:47 PM
