Shiftin w/out clutch
Old May 24, 2006 | 05:10 PM
ed_1's Avatar
Hey everyone, i recently got an evo like 2 1/2 weeks ago. And sometimes i shift w/out a clutch, i know for a fact if you do it right, it won't hurt anything. But i'm wondering whether is different to an evo? Thanks for the info.
Old May 24, 2006 | 05:13 PM
jrsimon27's Avatar
you will most likely damge something in time i would not recommend this to anyone
Old May 24, 2006 | 05:14 PM
evo-boy's Avatar
you just spent all that mony on a car are allready doing things like that before you know if it will hurt it. i dont know what else to say
Old May 24, 2006 | 05:15 PM
G20's Avatar
G20
Tsk, tsk, tsk... Very bad idea! Don't do it too often. :-)
Old May 24, 2006 | 05:19 PM
speedracer2169's Avatar
+1 what are you thinking? Have you seen what a new tranny runs around here? That's just a stupid risk
Old May 24, 2006 | 05:29 PM
Kay@kacework.com's Avatar
keep doing it.....
lowbdgtmechanic's Avatar
thats a NO - NO my child.
Old May 24, 2006 | 05:37 PM
MrMejia's Avatar
yes do it often. . . very often. Oh yea did I mention that its good for the tranny it makes it stronger actually. HA J/K, Don't do it. The best thing I would recommend for this car and any other manual car is Rev matching always.
Old May 24, 2006 | 05:39 PM
HIPSI9's Avatar
you must not like your trans , stuff like this make it hard to get trans war. out
Old May 24, 2006 | 05:41 PM
ed_1's Avatar
So the evo's have special synchros or what? As long as there's no grinding/unusual noise, it should be ok, that's what i was told by one of my instructors, but i don't know whether it applies to evo trannies, i see no difference. But i'm just trying to get an answer. And i don't do it 100% of the time i drive, cause i wasn't too sure about the evo trannies.
Old May 24, 2006 | 05:51 PM
VERACOMIX's Avatar
From what i have heard with the old muscle cars you can but you have to be very precise, if done wrong your gonna f' everything up, if i recall this is called power shifting, using the power and speed of the motor to suck the gear in with out using the clutch. But hey if you think you can do it try it out and tell us the outcome.
Old May 24, 2006 | 05:52 PM
PhoenixEvo's Avatar
Is this a jk? Shifting without the clutch......... ohh lord, help me plz " i wonder why the put this calf machine next to my clutch.... it must be used to long drives, so that u can fit your work out in!" Mitsu thinks of everything!
Old May 24, 2006 | 06:01 PM
ed_1's Avatar
The only thing with shifting w/out a clutch, is that you match the synchro speed to the gear speed. That's why i'm asking about a evo trannie, i've seen one apart, just the case, and it looks like any other tranny, except that the ring and pinion is like really thick. But thank you guys for all the info, i'll ask a mitsu tech, just to find out for sure. I only did it a few times. But i won't do it anymore til i know for a fact.
Old May 24, 2006 | 06:07 PM
jrsimon27's Avatar
MAN are you serious your gonna ask mitsu tech?? the car has a clutch pedal for a reason so use it!!!!
Old May 24, 2006 | 06:21 PM
Cirrusly Evolvd's Avatar
Yes you most certainly can shift it without the clutch. As long as you rev match the engine speed with the trans speed you won't grind or do any damage...that is the whole purpose of syncros. BTW, don't skip a gear while shifting...syncros won't help you there!
