2 clutches down...
Old May 29, 2006 | 12:21 PM
Sap12687's Avatar
2 clutches down...
Well after the stocker going at 13k and my clutchnet going at 15k (warped flywheel, piece of garbage) i now need another. I am looking around for something that is going to be solid for a daily driving/ track setup that will hold into the 400whp range. I do not plan on running anything larger than the stock turbo so please take that into consideration when giving me your opinion.
Also, as far as flywheels mine will need replacing. I have heard that too light is not good and id like to hear people's experiances with various brands. Thanks!
Old May 29, 2006 | 12:30 PM
ACTman's Avatar
For clutches, here is probably the largest poll and it keeps growing:
https://www.evolutionm.net/forums/sh...d.php?t=126768
If you are going through clutches that fast, you might want to consider taking out the restrictor in the hydraulics if you haven't already. The stock flywheel is pretty thin but it is a good piece. We have two different ones and both are much thicker than stock, but I will spare you the rest of the sales pitch.
Old May 29, 2006 | 12:39 PM
Sap12687's Avatar
Please dont spare it....i need all the info i can get. I did in fact remove the restrictor but i think that led to me warping my flywheel with some launches that were a little "too hard" and slipping through 1st and 2nd. Engagement is very harsh and i just cant take it anymore.
Old May 29, 2006 | 12:44 PM
ACTman's Avatar
If you removed the restrictor, it shouldn't lead to more slipping. PM me if you would like more info on our products.
Old May 29, 2006 | 12:46 PM
superflyevo's Avatar
i would go with a exedy twin if i was you and that clutch comes witha fly wheel
and you will not half to worry about the 7k lock out
unless the act man and his crew has figured out a was to stop that lock out thing
Old May 29, 2006 | 12:52 PM
Sap12687's Avatar
how serious is the lockout issue?
Old May 29, 2006 | 12:53 PM
MalibuJack's Avatar
The restrictor mod, if you have not done it yet, will reduce if not eliminate lockout at high RPM if your trying to shift quickly...
Old May 29, 2006 | 12:56 PM
there is alot of post about it (tons)
you jus got to adjust it all the time and you will not get the lock out
i had the act
i wished i had bought a twin disk
the shifting is even smother with a twin (i drove my buddies evo it had a twin i loved it)
Old May 29, 2006 | 12:59 PM
ACTman's Avatar
That "lockout thing" is going to happen on any clutch if the adjustment is not right. It is a dynamic problem with the engine (maybe crank flex), not just a clutch problem that we are dealing with. We are playing with a new design that takes less travel and provides more lift, so that less adjustment is needed.
Old May 29, 2006 | 01:04 PM
i adjusted mine so it worked perfect ,no 7k lockout but 2 weeks later it would need adjusted again,and again,and again,and again ect. it was never ending
im not bashing act but im deffentaly promoting exedy
Old May 29, 2006 | 01:26 PM
ACTman's Avatar
If it was happening again and again, then the issue is most likely warpage from the heat. If I remember right you were running the street clutch which is like comparing apples with oranges to the Exedy twin. Try comparing our race setup to the Exedy for more of a direct comparison (except for the price). Like the Exedy it has better heat capacity, requires less travel and has similar benefits/tradeoffs.
Old May 29, 2006 | 01:52 PM
can i get A link to this race set up
Old May 29, 2006 | 01:55 PM
Sap12687's Avatar
are you saying its a night and day difference between exedy twin and Act Street Disk? How so?
Old May 29, 2006 | 02:23 PM
ACTman's Avatar
Our website is not current since we lost our IT guy a few months ago so it doesn't show everything. But basically I am talking about a puck type disc with cerametallic material similar to the Exedy. The same kit is what TurboTrix uses on their cars. We have them available in spring center or solid center depending on the intended use. TurboTrix runs a solid center (lighter for quickest shifting).
Old May 30, 2006 | 01:02 PM
and u say it will work just as good as a exedy twin
what are the prices for a solid center ,cerametallic clutch
