Can the manifold and hotside come out as one unit with ebay o2?
Old Jun 4, 2006 | 07:31 PM
Zeus's Avatar
Originally Posted by damianhindley
No I want to leave the turbo in the car, just pull the manifold-hotside and o2 as a unit.
I have had my ebay manifold for like 8 months and no leaks, cracks or issues at all. I noticed a good power gain with it, and seemed to pull harder up top. But I have to tap a egt for zethronix. And its easier in the stock manifold. I think im going to add the ported stock mani, and 10.5 hotside. I will do a before and after log with the zethronix and see what it looks like. Ill post the results up and if its no good ill send the ecu out to Al. I just cant afford a 3ed custom tune. And i have meth, so Im hopping he can sell me an email update on my tune and i can use ecu flash.
It is not likely you could do it without really screwing up the turbine blades... killing your turbo. Now if you had already replaced the studs in the hot side with bolts (DO this with your new hot side!), you could easily pull the manifold off first, then the hot side with the O2 still attached. You still have to be damn careful with those blades.
Old Jun 5, 2006 | 01:54 PM
damianhindley's Avatar
Thanks bud, ill go your route
TomekEVO
20
Jul 28, 2014 03:46 PM
JYD
20
Sep 29, 2010 09:19 PM
TwistedEvo8
15
Oct 4, 2009 05:58 PM
ModifiedMR
55
Feb 5, 2009 01:59 AM
lbcevo
Feb 2, 2006 08:51 PM
