2.3 w/ 20G HELP.
Old Jun 6, 2006 | 01:33 PM
7State's Avatar
2.3 w/ 20G HELP.
Can anyone give me a ballpark figure of how much HP would be put down from a 2.3 W/ a 20G Dynoflashed, Stock intercooler, RS intake, Hi Power 30th Cat Back, Perrin Downpipe, and Helix Cat Delete?
Old Jun 6, 2006 | 01:35 PM
superflyevo's Avatar
i would say around 330
Old Jun 6, 2006 | 01:38 PM
Erik@MIL.SPEC's Avatar
Not that there's anything wrong with Dynoflash, but why would you use that option when there are plenty of good tuners in the area? Alfred @ Tuning Tech is one of the ones that comes to mind. He does ECU+, Open Ecu, XEDE, S-AFC and AEM. There is also Scott Gray (who tunes at both TT and RRE) and RRE, among other places.
Old Jun 6, 2006 | 03:29 PM
nrcooled's Avatar
The 20G is the weakpoint in your setup. You might as well keep the stock turbo. Save some cash and match your 2.3 up with a 50trim or a 30 series
Old Jun 6, 2006 | 03:41 PM
trinydex's Avatar
boost controller? you'd be around 370 without cams. with cams you would hit 400. i say this mainly because there is a dynograph of a 2.3 on STOCK turbo and it made 400 with 272s and everything else.
i also believe it is on pump gas....
Old Jun 6, 2006 | 03:45 PM
EvoTech's Avatar
the beauty of the strocker is how it helps spoolup. If you are gong that route you should go with a bigger turbo to match.
