Warralton, pressure tester questions...
Old Jun 13, 2006 | 08:07 AM
RoughedgesMR's Avatar
i made a pressure tester for my s4 with some pvc and compressor fittings. I attached it to the intake side past the maf. I was wondering if there is anything different with the evo. I was going to make a adapter that connects to the turbo inlet hose to pressurize the system. Is this wrong on the evo? Thanks for the advice. I would limit the compressor to the boost i am running.
Old Jun 13, 2006 | 08:13 AM
ibanez_926's Avatar
i guess i cannot answer this question....
Yes, it is the same. I put my tester on the lower intercooler pipe tho.
Old Jun 13, 2006 | 08:16 AM
Any particular reason why you choose the lower ic pipe?
Old Jun 13, 2006 | 09:10 AM
ibanez_926's Avatar
I have that 2 piece buschur lower pipe. Its just a bit easier.
