Is it just me or..........(long)
Old Jun 13, 2006 | 05:54 PM
8urv8's Avatar
Just another person here looking for an opinion about a boost issue. Could the simple lack of a wire tie on the connection between a hose a t-fitting cause a boost leak? I'll explain as best I can. For a couple weeks now I have been on this kick about my car not pulling quite as hard as it should. One part of me says maybe you have a boost leak, the other says you are just so used to the feel of driving the car. Well I push the car a little harder today to find out. I did a 4th gear pull from 40 to 80 and the boost held strong at 19. Never spiked higher. So when I get home I pop the hood and see that the line that runs from the t-fitting to the hallman mbc has no wire tie on it like the rest. About 3-4 weeks ago I ran new all hoses. So I do it up with a tie. Just for fun I decide to see if the old hallman is working right. I turn it down 2 full turns from where I have had it set. I close the hood and go do some pulls. Yup the boost is down at like 15 or so. Ok seems to be adjusting the boost fine. So I turn it back up the 2 full turn I turned it down previously. Do some pulls in 4th again and the boost is now 21-22 spiking a little higher, at what I am sure was the same setting on the mbc when I was only hitting 19 just before putting on that little wire tie. I hit fuel cut off a couple of times and the SES light came on. Could the simple lack of a wire tie on that hose caused this? I touched nothing else under the hood.
Old Jun 13, 2006 | 05:57 PM
Bimmubishi's Avatar
Probably not. I would venture that you reset the Hallman to a different place after the test session. If I were you I'd try a pressure test on the turbo system and if it passes it's probably in your head.
Alex
Old Jun 13, 2006 | 06:02 PM
kimletrim's Avatar
Registered User
The boost leak test will provide you with almost all of your answers you seek.
Old Jun 13, 2006 | 06:10 PM
8urv8's Avatar
Alex
That is what I was leaning towards. I think I miscounted the turns when I put it back up.
