Tial Wastegate gasket fried!
Old Jun 14, 2006 | 05:21 PM
exhaust_note's Avatar
ive never seen this.. the gasket between the wastegate and the manifold fried and exhaust gas was leaking past it...
has anyone ever heard/seen this and know what to do beside s replacing the gasket?
Old Jun 14, 2006 | 05:23 PM
levo2nr's Avatar
it happened to me before just get a new one
Old Jun 14, 2006 | 05:36 PM
ExViTermini's Avatar
vband is where its at
But yes you can just buy a replacement gasket. Checkout cheapturbo.com, atpturbo.com, slowboyracing.com....
Or just go to a local shop and if they do a lot of turbo work they should def have one.
Old Jun 14, 2006 | 06:13 PM
CBRD's Avatar
if youre running the 38mm they are pretty standard,
race gas tends to eat them up.
slowboyracing has copper and ss ones i believe.
we've had good luck with them
cb
Old Jun 14, 2006 | 06:42 PM
evolved4g63's Avatar
I think turbonetics makes one with a solid metal ring surrounded by the regular gasket material. I blew the regular ones out but not that one.
Old Jun 14, 2006 | 07:15 PM
dubbleugly01's Avatar
are you sure you had the wastegate bolts tight on both sides? A little gap from improper tension on the mounting bolts will fry the gasket rather quickly.
Old Jun 14, 2006 | 07:19 PM
they were tight, they were hard as hell to get off
Old Jun 14, 2006 | 07:21 PM
fimotorsports's Avatar
I'm assuming it's the 38mm Tial, if so, get the turbonetics gasket it has a fire ring and you won't have an issue with that one.
Old Jun 14, 2006 | 07:28 PM
xepyt's Avatar
I did :[
Old Jun 14, 2006 | 08:25 PM
PeakBoost's Avatar
very common problem with the 35/38mm wg.
we actually dont use a gasket on them at all. high temp copper sealant
Old Jun 14, 2006 | 09:46 PM
silverofs's Avatar
i don't use anything and my 38mm seals fine with no gasket had a friend tell me to do that...
Old Jun 15, 2006 | 01:11 AM
thanks guys, i got another gasket and tightened it up differntly, tightend up the wastegate to the mani. first and then to the dump
Old Jun 15, 2006 | 07:47 AM
bolsen's Avatar
I don't believe you need a gasket for this wastegate. I was under the impression that the silver metal ring was the gasket.
Old Jun 15, 2006 | 08:08 AM
vwjeff's Avatar
You are correct, I don't use one on my GTi and it see's 30 psi almost all the time
Old Jun 15, 2006 | 09:05 AM
Steve@NoLimitmotors's Avatar
Tial suggests not using a gasket at all if it blows out as long as your using a tial flange to mount the gate to. if you want to be extra precautious, try some copper spray
