Tial Wastegate gasket fried!
Originally Posted by exhaust_note
ive never seen this.. the gasket between the wastegate and the manifold fried and exhaust gas was leaking past it...
has anyone ever heard/seen this and know what to do beside s replacing the gasket?
Originally Posted by Steve@NoLimitmotors
Tial suggests not using a gasket at all if it blows out as long as your using a tial flange to mount the gate to. if you want to be extra precautious, try some copper spray
This is sorta off topic but what affects did it have on you when it got fried, trying to diagnose my issue right now. Other night I was heading home from work, boosted and heard a pop and now when I spoolup when the wastegate opens up my wg sounds different (actually quieter) my boost spools up slow, and when it reaches 20 it is so sluggish it feels like 8psi even though gauge reads 20.
Took off intake fins checked out ok, no shaftplay etc. Put intake back on, drove it and the first pull in 1st/2nd it spooled fine then merged on the highway in third it popped again and did the spool issue again.
I never used a gasket on my 35mm and then on the 38mm when they came out. Try running the wastegate without a gasket and see if that works for you
