Engine Bog/Sputtering
Old Jun 26, 2006 | 07:01 PM
702RSevo's Avatar
Question Engine Bog/Sputtering
Ok so i was on the way to school today and was going about 60 then i step on the gas to chage lanes and get it up to 75 and i hear this loud bang/backfie and then the car boogged down. i get over and turn it off and look for anysmoke or any sign of anything broken. i then start it up and drive it down to the dealership on the way there i noticed it wouldnt go over 30 mph maybe due to the ses light on. so i get it to the dealership and they pull it off and i notice alot of black smoke coming out of the exhaust.. in the past i have only got a p0300 code and that has been off for the past week and a half....
Old Jun 26, 2006 | 07:05 PM
smokedmustang's Avatar
Popped off hose?
Old Jun 26, 2006 | 07:17 PM
702RSevo's Avatar
i didnt see anything but i was able to make it to the dealership service dept. so i will def get a answer tomorrow...
Old Jun 26, 2006 | 07:29 PM
Something happened to put you in "LIMP HOME MODE" that is what happened. it is to protect your car from larger failure. it will run to get you home, or to the shop, but that is IT! Probably something easy to fix! Don't sweat it.
Old Jun 26, 2006 | 07:30 PM
elhalisf's Avatar
almost sure a hose popped off
the engine couldn't go over 2k rpm on 5th gear, right?
Old Jun 26, 2006 | 07:33 PM
When I blew a hose off, I couldnt go ANYWHERE, just pull off the side of the road, and try to start it again, to no avail, and had to reconnect the hose, or FORGET IT!! You can't drive a car any distance with the hose off. he is in LIMP HOME MODE!!
Old Jun 26, 2006 | 07:48 PM
Warrtalon's Avatar
Too easy - intercooler pipe. If it's not obvious, look at the LICP under the car connected to the turbo or FMIC.
Old Jun 26, 2006 | 08:47 PM
702RSevo's Avatar
thats another thing i was thinking after i saw how rich it was running since im tuned and all we shall see tomorrow. what code should it have thrown up? i dont have a scanner
Old Jun 26, 2006 | 09:26 PM
Warrtalon's Avatar
Doesn't really matter - it's for sure your IC piping.
