Evo 8, 91 octane: Should I worry about knock?
First off, great site, great resource.
If I read Shiv's reports correctly, it seems like the stock Evo 8 has real issues with higher-RPM knocking when running on 91 octane gas. I don't know much about dyno loads and all that but my understanding has always been that knock, over time, is going to be trouble.
Is this a real concern? Will the car adjust itself to the gas I'm running eventually and neutralize knocking problems? If and when that happens, what kind of power compromise will it mean?
Thanks guys
- EZ
Thanks guys
- EZ
Guest
Posts: n/a
The ECU should normally pull the timing when the car isnt run on the 93 octane gas it is intended to run on. I'm not sure if there's a limit to how much timing the ECU can pull, but if there is, there may be some knock left. This is of course bad and shouldnt happen. Either you run 93 octane like you are supposed to or you have the ECU reprogrammed by your tuning shop in order to accomodate the lower octane gas.
All indications at this point are that the ECU can and will pull enough timing to compensate for the 91 octane and offer sufficient protection to your engine. The consequence though is a significant drop in performance over 5k rpm and associated peak power losses. 93 octane will make it feel like a different car over 5k. Check out some of the tuners' sites on the left coast where 91 is the norm to see what they are saying.
Reading the owner's manual, it actually goes so far as to say that the engine was designed to work with 98 octane (!!!).
The semi-good news is that I found an area gas station that sells 100 octane: for those of you in the SF Bay Area, it's the 76 station at the corner of Almaden Expwy. and Foxworthy Ave. in San Jose. It is semi-good news because it's a good 20 miles away from where I live and because 100 octane costs twice as much.
Guest
Posts: n/a
98 octane in Japan equates to 93 octane (or 92.5 or 93.5, something very close anyway) in the USA.
Here in California, we can only get 91 Pump Octane wich is about 95 RON. Does this mean I am already voiding my warranty by loading only 91 Octane. Looks like I will need to get racing fuel concentrates for every fill. I have used this on my MR2 Turbo and boosted 19 lbs and no knocks. Here is a link.
http://www.torcoracefuels.com/ACCEL%201.htm
If you can blend 100 racing with 91 pump to get 93+ in the tank. I'm lucky enough to live close to a station that sells 100 and do that. We really get the shaft in California. Not only do we only have 91 we also pay 2 dollars or more per gallon for it these days.
Originally posted by Claudius
That is Japanese spec 98 octane; they just translated the text when translating the manual I guess.
I knew we had different rating system but didn' quite know what difference was....we also have 100 rating gas as well (Japan rating) a sidenote.. question for the guys in US.....I,m starting to see more and more US products over here and was curious about the Octane boost products. Any good? Is worth the money?? I was thinking about trying some made by NOS (race only formula) Has anybody here tried this product before??
Originally posted by ishi
Thanx for info
Thanx for info
As for my car which has Vishnu Stage O plus downpipe and high flow cat. there is no knock or problem or drivability issue whatsoever. Its totally like a stock car only somewhat faster.
Given a little time - from what I see going on around Vishnu's shop, (I live nearby) many of the problems attributable to Calif. 91 octane fuel will get sorted out. There are clearly other ways to deal with much of the octane problem besides just going to different gas. In time, it will be very engouraging how much we can get out of the Evo on 91 octane. Of course this will involve doing things which will void the warranty. And all this takes time to put into place when dealing with the factory ecu. The upgrade path will not be conventional; i.e. not what you see everyone talking about in these forums. Look for some interesting mods that are not even being discussed at this time.
Patience pays!
Patience pays!
Thanx for the advice and saving me few bucks...er, yen
