HELP BOOST LEAK testing
Old Jun 28, 2006 | 10:04 AM
EvoDan2004's Avatar
ok so im making a new thread cause the other one was filled with things that was fixed. now for the leaks that i cant find. sounds like there is a leak on top of the valve cover. i looked at the plugs and that is fine. when i open the oil cap i here air inside. should that be happening?. also you know the lil 4 inch rubber hoes ontop of the valve cover? it is on the top right of it. sounds like it is coming from that area. its not that line tho. any idea's.
