Has ANYONE had this problem" drivetrain/driveshaft"
Old Jun 29, 2006 | 03:56 PM
WickedWhiteRS's Avatar
Hey I was just wondering if any one has had to replace the bearings I believe called the carrying bearings. Located in the middle if the car where the front piece of the driveshaft connect to another piece "about two feet long,they have bracets around them"and then connects to the rear piece of the driveshaft into the rear diff. The problem is I have replaced the propeler shaft bearing "spelling" which leads into the driveshaft to the rear diff which looks like a round piece of metal with I think six bolts going around it. The problem I have is the drive shaft is flexing to much in high gears off the gas causing a rub into the exhaust."Trust me if has nothing to do with my exhaust,Transfer case, or Rear diff" I have already order the bearings from mitsu which are located in the middle of the car about a foot apart from each other which support the driveshaft. They have bracets around them held in by a twelve or fourteen mm bolt. I was just wonder if ANYONE knew if there was somewhere I could find a stronger aftermarket bear for these bearings. I don't want to have to keep on replacing these and was hoping some has had the same problem. Thanks to anyone who takes the time to read this. Happy fourth of July weekend to everyone!!!
Old Jun 29, 2006 | 04:19 PM
Noogles's Avatar
i've never heard of them failing, it's probably an isolated incident.
No aftermarket part exsists.
Old Mar 31, 2008 | 05:57 AM
slvevo8's Avatar
same thing is happening to me i beleive, car is at dealership now....
wbresson
Jul 9, 2022 06:21 PM
MisUnderStood
49
Aug 10, 2016 08:27 AM
EvoDan2004
60
Jan 24, 2015 12:52 AM
smokedmustang
33
Aug 16, 2012 10:35 AM
AutoMotoSports
41
Dec 21, 2005 04:15 PM
