boost gauge mechanical install help!!
Old Apr 24, 2003 | 06:36 PM
thuan's Avatar
Oh one more thing did the car come with predrill hole porting to the inside of the car? If not whats the best place and how do u rune the vacuum line into the car? Any drilling involve?
Old Apr 24, 2003 | 08:32 PM
Option2's Avatar
This is what I did:
Sorry about the last pic. I know it's not very clear.
Old Apr 24, 2003 | 09:01 PM
thuan's Avatar
Tnx for the info.
its all install tnx alot of your help
Old Apr 24, 2003 | 09:52 PM
netmand's Avatar
Originally posted by 2Cool
Its easy, there is a single 3/16" line running down to the turbu along the intake tube from the filter box area. It has a "Y" fitting into two lines, one of those lines runs to the wastegate on the side of the turbo, the other to the outlet side of the turbo. Basically you disconnect those two lines from the turbo, plug em off and zip-tie them out of the way. Then run two lengths of vacuum line from where the old lines were connected up to your boost controller. Thats it.
Pics to back this up:
BIG PIC
....er um but this is for boost controller, so sorry for being a bit off topic.
Old Apr 24, 2003 | 09:59 PM
netmand's Avatar
*shaking head at Option2* sorry man, you gave up too quickly.
Please look here... I'm in the middle of my guage install (running into ordering snags) but borrowed a friend's mechanical boost guage and hooked it up. The proper route for your wires and vac lines should go where I routed them:
http://www.collectracecars.com/evo/mechgaugeinstall.htm
Old Apr 24, 2003 | 11:38 PM
Option2's Avatar
Whoa.... i'm just tryng to help the guy out. The end result is the same is it not? There are many ways to skin the cat.
Old Apr 25, 2003 | 12:17 AM
mrdecibel's Avatar
I agree with NETMAND, this is not the best location. The reasons why are (A)Unnecessarily exposing cables/tubing to the elements by going outside the engine bay. (B) Your wire appears to be very close to a moving part (could get pinched or sliced).
I chose to drill a new hole due to wiring I used for my stereo install. Kinda hard to squeeze 0 gauge in a factory grommet.
Netmand's location is great BTW.
Old Apr 25, 2003 | 12:58 AM
hel_if_ino's Avatar
you know, there is also a rubber boot above the drivers side kick panel which exits directly behind the driver side fender, where you can route the boost gauge line that way.. thats how i did it.
Old Apr 25, 2003 | 09:28 AM
netmand's Avatar
Hey kudos to you for taking the time to get pics and post them, really that's what this forum is here for... but all pieces of information shouldn't go unchecked:
Be careful of how you did your line routing... cutting the wire boot that goes into the side of the car leaves an opening for water to get in... usually not much water is going to wind up there... except you have a line running from above going right into the hole... yep, water is going to travel right down that hose and right into the car!
Just trying to be constructive here. No offense intended.
hussein
Feb 17, 2017 11:11 AM
xpehbam
Sep 11, 2008 10:32 AM
edtxag
Jul 31, 2004 09:14 PM
Y2A
Nov 15, 2003 02:38 PM
tlin8
Oct 30, 2003 06:15 PM
