oil pressure gauge vs fuel pressure gauge
Old Jul 30, 2004 | 12:42 PM
edtxag's Avatar
WHich gauge do you all think is better, i am running boost, egt and not sure on the third gauge to go with.
Old Jul 30, 2004 | 05:20 PM
Wizard_of_Evo's Avatar
oil
Old Jul 31, 2004 | 06:02 AM
LateSleeper's Avatar
I believe in order to run a fuel pressure gauge, you need to have an aftermarket fuel rail. From what I've read, there is no where to tap the sensor for a fuel pressure sensor.
Go with the Oil pressure.
Old Jul 31, 2004 | 06:16 AM
EVO8LTW's Avatar
I was planning on boost and fuel pressure gauges on the steering column. It seems to me that it's a lot more likely for your fuel pump to start going south than to start losing oil pressure. On a track the oil pressure might be nice to make sure you aren't losing pressure in long sweepers though.
So no one has installed a FP gauge with the factory rail? There's got to be a way to do that. I haven't really looked at it yet.
Old Jul 31, 2004 | 06:26 AM
tweakdsm's Avatar
oil
Old Jul 31, 2004 | 06:28 AM
turboDan's Avatar
To use the stock fuel rail and tap in a fuel pressure gauge you will need one of these http://www.pruvenperformance.com/evofuel.html .BTW,
go with the fuel pressure gauge,alot more important when tuning your car IMHO.Your idiot light will come on if you lose oil pressure,but the only indication that you are losing fuel pressure besides your car running crappy is detonation=burned piston over long periods of time
Old Jul 31, 2004 | 04:52 PM
__NiTe__'s Avatar
Both!
Old Jul 31, 2004 | 07:48 PM
Scottybob's Avatar
Well, you do have an oil pressure warning light. Fuel pressure problems will be reflected in EGT.....
Old Jul 31, 2004 | 08:29 PM
SoR's Avatar
SoR
How reliable is the warning light though? I'm actually in the same dilema and when I think about it, higher EGT will show me fuel delivery problems but it might not necessary mean my pump is dying out which I think fuel pressure gauge might help detecting.
Old Jul 31, 2004 | 09:14 PM
LancerEvoMR's Avatar
Moving to FAQ's Forum.
hktrigguy
Jun 16, 2017 05:23 PM
minimarine09
For Sale - Part Outs
Mar 14, 2017 12:02 PM
butters149
Oct 16, 2015 10:25 PM
FastMD4G63Drive
Oct 16, 2008 11:32 AM
Y2A
Nov 15, 2003 02:38 PM
