Sputtering/Fuel Cut at 23PSI
Old Jul 1, 2006 | 02:11 PM
KazzEvo8's Avatar
I've been running 25-6psi w/no problems since tuned. MBC & BOV in-place. I installed a Buschur COP today and went to wash the car. On the way back I hit it hard in 3rd getting on the interstate and she it about 23psi and started sputtering or fuel cut or something. I let off quick. Tried it once in second and same thing.
I've hooked it up for a boost leak test but didn't have anyone to watch the gauge. I put some good pressure in it w/my compressor and stopped - the homemade pressure tester with PVC cap and valve blew off. I'm getting help and I'll retighten but could this be something else?
She was fine driving home last night other than a 401 code, found the EGR solenoid hose was off and put it back on.
Anything else while I go test this thing?
Thanks!
Old Jul 1, 2006 | 02:50 PM
KazzEvo8's Avatar
Hmmm, apparently the consensus is "spark blowout" ... I'll be reverting to stock.
It seems a COP is useless without a spark amplifier. Nice to know now. I rather thought it might help guarantee a clean spark for each plug. It seems do decrease the power of the spark instead.
Delightful.
Anybody wanna buy a Buschur COP only used for about 18 miles... ?
Old Jul 1, 2006 | 03:27 PM
Guerillah's Avatar
I feel your pain.
Old Jul 2, 2006 | 07:12 AM
dan628's Avatar
If you're looking to do something with your iginition try the Sun hyper force... its full plug and play...
Old Jul 2, 2006 | 04:10 PM
KazzEvo8's Avatar
Yeah, sell my COP ... that's what ...
Old Jul 2, 2006 | 06:58 PM
KILTERMAN's Avatar
IS the HKS DLI2 the same as Buschers COP? IS the HKS Unit plug n play aswell?
Old Jul 2, 2006 | 07:58 PM
KazzEvo8's Avatar
Look on their site. Their COP doesn't include electronics. Just four coils on a plate.
Old Jul 2, 2006 | 08:14 PM
DynoFlash's Avatar
Man you should just add the Buschur ignition box and your spark will be VERY strong
You would need to add ignitors to run the cop along without the ignition box
I run the Buschur ignition and COP in my race car - it is an amazing unit !
Old Jul 2, 2006 | 09:35 PM
KILTERMAN's Avatar
Kazz your entire situation sounds similar to mine. My tuner is suggesting I get a HKS DLI2 to reduce spark blowout. You said that the HKS unit doesn't come with electronics? Didn't know that. I will have to read up before I purchase that bad boy.
Kazz:
Was this the 1040.00 COP system that bushcer sells now or the old like 400.00 one of old?
Old Jul 3, 2006 | 06:51 AM
KazzEvo8's Avatar
Roughly $400 unit. It's not marketed as HKS, just as Buschur's, at least when I bought it. It is not listed on their site anymore.
I've now hacked up the short wires before the connectors enough I'm not motivated to change anything unless I truly decide I need the extra spark. Not that I've done a sh!tty job - just that there isn't that much to work with.
I'd have to throw another $500 after the $400 I've already spent it seems - still not motivated until I know I need it I guess...
Old Jul 3, 2006 | 09:48 AM
nosbrody's Avatar
try to re-check the ic piping, and see if ur pump is flowing right, it might be failing
Old Jul 3, 2006 | 10:22 AM
EvilBlueEvo8's Avatar
a ignition amp should be installed before a cop setup. the hks is a nice unit since its plug and play but costs a bunch. can get the xs engineering unit for much less if you don't mind soldering two wires and hooking up a ground. really simple job. 45 min and that includes mouting the unit
Old Jul 5, 2006 | 04:20 PM
KazzEvo8's Avatar
Thanks!
Old Jul 5, 2006 | 04:40 PM
dan628's Avatar
I already said to get the Sun hyper force, its basically the same as the HKS, easier to find sometone with it in stock, and cheaper, what more do you want?
supzack
Oct 17, 2015 11:46 AM
Evo-IXse06
Aug 10, 2015 03:21 AM
yikez
74
Jan 22, 2011 09:33 PM
merlin00069
Apr 27, 2009 08:56 AM
justchil
17
Jul 7, 2007 07:30 PM
