max psi for IX diverter valve
Old Jul 2, 2006 | 12:05 PM
joek84's Avatar
Im looking into alky kits and i was wondering what's the highest boost i can run with my stock IX diverter valve. Will it hold up to 30 psi?
Old Jul 2, 2006 | 12:13 PM
fromWRXtoEVO's Avatar
I went to the local track one night (SIR, Tucson) with the stock BOV on the Evo 9. I put 2 gallons of 104 Sunoco to an already exiting 4 gallons of 91oct with the boost adjusted to 27PSI.
After I finished from running the car at the track I was driving on the HWY. I turned the boost up to 27psi (peak)and the car started leaking at 27psi(peak) while driving in 5th gear pedal to the floor at around 60-70mph. The BOV will open and close in a vibrations mode while the boost gauge would flutuate slightly +/- 1psi while making the psssshhhhhh noise. My boost gauge also records boost and plays it back(Defi plus controller)
I can only speak for myself and my car, I don't know what others can run, I am just saying what I have seen on my Evo 9. I hope that helps you
Mods on the Evo 9:
3"TB, Dynoflash mail-in,Buschur Cone,Unos MBC
Carlos
Old Jul 2, 2006 | 12:20 PM
jcsbanks's Avatar
Carlos, if it clears after about 4000 or so RPM I get the same (if I run that sort of boost level) and it is compressor surge.
Old Jul 2, 2006 | 12:37 PM
jcsbanks,
My observation is that it holds the 27psi most of the time while in tall gears only at a midrange rpms (4000rpm would be appropiate to say on this case). Anything much higher rpms wise and the boost vanishes, anything much less and you can build enough boost.
I am sure people might have their reservations believing me but it is OK. I live in the desert and I go testing my cars all the time, I record everything, weight, temp, boost and other factors.
I know that not many people ran 27psi without any kind of methanol/alcohol but I ran 27psi peak on a race gas mixture and the car held the boost in 5th gear no problem for a few seconds.
JCSbanks, what part of UK are you from?, I raced at Santa Pod, it is a nice place there.
Carlos
Old Jul 2, 2006 | 03:22 PM
matt55's Avatar
mr valve starts to leak @22-24 psi (pressured tested on a bench , not on the car) , you can run more psi but it leaks...
Old Jul 2, 2006 | 03:25 PM
Guerillah's Avatar
well that sucks :/
Anyone try crushing it?
Old Jul 2, 2006 | 04:00 PM
matt55's Avatar
^----one guy did (search the dynoflash-forms) and he talked about the driveablety getting worse
Look into to a Forge RS bov there spoes to be the "bees-knees" when running high psi
Old Jul 13, 2010 | 01:09 PM
boczo777's Avatar
so whats the best diverter valve for evo 8, holding like 27psi and not costing tons of money??
i was thinking bout getting oem ix valve for my evo but if it leaks at like 24psi its pointless
fugiwara
Jun 24, 2016 04:24 AM
fugiwara
Jun 1, 2016 02:13 AM
stabiemcstabin
13
Dec 3, 2010 06:17 PM
xtnct
12
Jun 14, 2007 08:21 PM
xtnct
Jun 13, 2007 07:27 AM
