oil squirters needed?
Old Jul 7, 2006 | 11:04 AM
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
If your gonna build a 2.4 liter engine with coated pistons(dish and skirts), are oil squirters really necessary? Say on a daily driver car?
Old Jul 7, 2006 | 11:07 AM
nutrulz's Avatar
insurance.
Old Jul 7, 2006 | 11:19 AM
anjapower's Avatar
not necessary with forged internals.
Old Jul 7, 2006 | 11:26 AM
dont the 4g63s have forged pistons?
Old Jul 7, 2006 | 11:46 AM
Aby@MIL.SPEC's Avatar
for a daily driver, drag racer, oil squirters are not necessary.
if you plan on tracking your car, running it hard, then i suggest installing them. oil squirters reduce the piston crown temps a bunch, but if you arent hammering the car for an hour at a time, i wouldnt sweat it.
just make sure the tune is safe.
Old Jul 7, 2006 | 11:56 AM
excellent, thank you.
Old Jul 7, 2006 | 12:06 PM
ohio-evo's Avatar
I thought the evo's had oil squirters.
Old Jul 7, 2006 | 12:14 PM
mchuang's Avatar
They are there to cool the piston. If you remove them though I think you still have to plug up the holes, because you will lose oil pressure.
Old Jul 7, 2006 | 12:22 PM
Ted B's Avatar
EVOs do have oil squirters. The original post inquires about a 2.4L, which uses a 4G64 block (not an EVO block), that does not have oil squirters.
EVOs are not equipped with forged pistons.
Old Jul 7, 2006 | 12:26 PM
thanks again ted
Old Jul 7, 2006 | 03:50 PM
VTEC Killer's Avatar
Make sure who ever is boring your block uses a torque plate, because if your skirts are coated and a torque plate is not used, you have a 90% chance of wearing all that coating off and having it go right into your oil within a few minutes of the motor running. You need to make sure you have ideal piston/wall clearance under tension with the head on. I had the factory coated wiseco's in a motor that was not bored with a torque plate, the coating wore off in about 200 miles.
Old Jul 7, 2006 | 05:35 PM
94AWDcoupe's Avatar
For 10 seconds down the strip they are not needed. Chasing down that R1 on the highway your gonna want them. Mitsubishi installed two squirters per piston for a reason. Forged pistons need it even more because they swell more than the factory material. I drill my rods and fit the block for squirters when I build a motor for myself.
Old Jul 7, 2006 | 05:40 PM
zlancer's Avatar
Anytime you machine a block you should use a torque plate. It just doesn't make sense not to.
Old Jul 9, 2006 | 12:50 AM
trinydex's Avatar
why not? forged internals don't need oiling?
Old Jul 9, 2006 | 01:42 AM
elhalisf's Avatar
two oil squirters per piston??? i only saw one per cylinder.
