which cams for evo 8
Old Jul 11, 2006 | 12:36 PM
Corey's Avatar
I bought 264's that were used and stepped up to some used 272's not too long ago. I can tell a big difference between the two as far as topend goes. Plus 272's sound better.
How you like your car with the 02 and hotside? I have both sitting in my garage waiting to be installed. Could you tell the difference any?
Old Jul 11, 2006 | 12:47 PM
SwabeLife's Avatar
I really can't tell, coz I put them all at the same time. After installing all of them, WOW!
Old Jul 11, 2006 | 12:49 PM
SwabeLife's Avatar
Originally Posted by hondafan
does anyone know which cams definitely do not require valvesprings/retainers and which ones do?
Do I need those too? If I get HKS cams and gears?
Old Jul 11, 2006 | 12:54 PM
BenjyJ's Avatar
If you get hks 272/272s youre fine with the stock springs and retainers.
Old Jul 11, 2006 | 01:08 PM
nigletsyz's Avatar
any of the hks cams you are fine w/ the stock springs and retainers. they all have the same lift. Upgraded springs and retainers are for agressive profiles like revolvers/juns and/or if you will be revving at 8K+ rpms.
Old Jul 11, 2006 | 01:15 PM
Speed Element's Avatar
i got 4 sets of HKS 272s in stock! pm me if you are interested. free jdm t-shirts when purchasing today ($30 value!).
Old Jul 11, 2006 | 01:28 PM
Gruppe-S's Avatar
Helix Super-Light Cam gears & 272 Camshafts - $449 shipped, $599 Installed. No need for valvetrain. We have HKS & gears in stock also, but with the pricing on the Helix Cams, I don't foresee we'll be selling a lot of them anymore. If you want a 264 or 280 setup you should consider going with the HKS, but on the 280's I would recommend porting and headwork. The idle is also quite rough.
Cheers,
Gary
Gruppe-S
Old Jul 11, 2006 | 01:30 PM
Dr. SS's Avatar
Originally Posted by 9xfaster
I had 280's in my car on the stock turbo . The idle was harsh, but I liked it.
If I had to do it over again, I'd get the 272's. But on a bigger turbo I think I'd use the 280's.
stock turbo, hae 272's. they fuxin roxor
Old Jul 11, 2006 | 02:20 PM
Gruppe-S's Avatar
If you're going the springs / retainer route, definitely look at the Revolver setup. The huge lift and duration (thus requiring springs and retainers) is a big plus for the built motor car. However if you're not running built motor / built head / big turbo, I'd stick with the 272's. Helix ones we're doing at $349 right now, revolvers are double if not triple the price (worth it if you're heavily modded though).
Not all cam gears are created equal (though I haven't seen a non-adjustable one). The Helix ones weigh less than 1lbs each, which is a huge difference in rotating mass, I'm running the Helix ones just for the weight difference, creating an additional +1 degree of overlap is nice, but didn't do much for me on the 20G turbo. The lighter gears definitely rev happier though.
Cheers,
Gary
Gruppe-S
Old Jul 12, 2006 | 08:00 AM
SwabeLife's Avatar
Do I need to change belt if I get a new cam gears?
Old Jul 12, 2006 | 08:05 AM
PPI's Avatar
PPI
No you don't. You can follow the manual's recomendation for when to change the belt.
Old Jul 12, 2006 | 08:49 AM
Z1 Performance's Avatar
ether a 264/272 or straight 272
264/272 will give you a bit broader of a torque band down low, and has an idle nearly indistinguishable from stock. Straight 272's have a bit more of a "I have cams" sound at idle, even with a perfect tune (Sean does great work BTW!)
If you plan down the road to build a motor/head and/or go larger turbo, do the straight 272's. If you never plan to change your turbo, or never plan to build an all out head/bottom end, either the 264/272 or straight 272's will work well
You'll have zero need for cam gears with either setup given your current mods
We've also got 1 set of 272's at the old price too (HKS pricing went up on cams on June 1)
Old Jul 12, 2006 | 10:26 AM
ibanez_926's Avatar
I got 272 gsc's with stock cam gears.
Everyone on here is going to tell you that the cams they bought / they sell are the best
In my personal opinion cam gears are overrated
Old Jul 12, 2006 | 10:36 AM
they are by no means over rated - its a great way to manipulate the power band, but it needs to be done by someone who knows what they are doing, while a tune is being done. For the average Joe, I agree, they are overkill
Old Jul 12, 2006 | 10:47 AM
RED DEMON's Avatar
After SEARCHING i decided on 272/272 HKSs myself, having them installed next week.
Love it how simple threads turn into informercials with these vendors pushing their products...
NO buy the HKS 272/272s from me, at 134 easy monthly payments for $19.99 they can be yours!
(Just giving everyone a hardtime, dont worry! )
