Need Help car wont start
Old Jul 12, 2006 | 09:03 PM
elhalisf's Avatar
this is what happened with mine for the fuel pump.
did the fuel pump install. car ran great around my street. once i started boosting, it cut up real bad. one the way back to my house, the engine wouldn't go over 2k rpm. when i let the car idle, it would idle really bad at around 500rpm for a couple of seconds and then die. it won't have a problem starting up every time, but would die quickly after start up.
as for the no compression on #1 and #2, thats wierd. to get zero comp in those cylinders would mean that the valves for those cylinders are bent. did you install any cams or cam gears? do a wet compression test (put some oil in the cylinders) and see if the compression numbers increase
Old Jul 12, 2006 | 09:12 PM
ELF's Avatar
ELF
sounds like the same thing.....how did you fix the problem?
Old Jul 12, 2006 | 11:23 PM
ELF's Avatar
ELF
Thanks elhalisf....totally appreciate it man.....car runs!!
Old Jul 13, 2006 | 12:04 AM
SKILMATIC's Avatar
wow your rockers fell off you said? And you didnt even boost it hard ? I have never heard that happening before.
Old Jul 13, 2006 | 10:35 AM
fitch's Avatar
Actually, he never hit boost... just granny driving, not even hitten boost.... just drove the car around the block once or twice..... BUT its now FIXED guys.... THE FUEL PUMP WAS INSTALLED INCORRECTLY....
Old Jul 13, 2006 | 10:43 AM
theGman911's Avatar
So what was the final outcome? I thought you said you put the rockers back on and still no good.. So what was the final fix? Thanks
Old Jul 13, 2006 | 11:14 AM
SKILMATIC's Avatar
Awe ok. Wowzers, didnt know fuel pump could do that? Well glad to hear everything works.
Old Jul 13, 2006 | 03:40 PM
ELF's Avatar
ELF
i double checked the fuel pump and it wasnt in all the way so i reinstalled it and turn car on and it ran fine had good vaccuum and drove fine..........i was really lucky it wasnt anything major
