Need Help car wont start
like topic said car wont start.......so here is what i all did.i put on my 35r kit, fuel pump, fuel raill, injectors, hallman boost controller.....after all that i put on i started car up made sure there was enough oil and coolant and that checked out fine...took car around the block came back car drove fine...started car back up and drove around the block again.and no i was not boosting then i step on the gas and it bogs and dies.......push car back try starting it up and wuldnt start....finally change spark plugs got it to start but bogs like crazy at idle then it dies out.....
any advice what to check and do to get it running
Originally Posted by IEXCELR8
Stock ecu or standalone.
What did the plugs look like? wet? I think you are pig rich.
It turns over right?
Any back fires?
Any back fires?
Stock ecu.......
bpr8es for the plugs
it turns over but bogs then dies....
just lookied inside spark plug holes and see oil floating and did a compression test 0 pressure in cylinder 1 and 2 and 150 pressure in cyliunder 3 and 4...do you think its the head or bottom end?
Originally Posted by speedracer2169
no tune or safc?
i had a scheduled tune so i put everyting on and made sure it was running right then gonna get tune on the 29th of this month
to start
What size injectors? The cylinders are fuel washed. remove the injectors you put in and replace with stock ones. Replace the spark plugs because they are fuel fouled too probably. For now go hotter (7's stock) or 6's. You will have to get the fuel out of the cylinders. This should bring the compression backup. If your worried anbout hurting the motor to drive it like this then only let boost minimally. You need a tune have it run properly now.
okay so we took off valve cover and discover 2 rockers fell off..........now tryiong to put it back ...hopefully it will work....has any one seen this this before? and what did you guys do ?
did all that put back on stock injectors and running stock plugs? but found out rockers fell off? hopefully nothing was damage? and suggestions.and you should take fuel out of cylinders...how should i do that....
Try and dry the cylinder out as much as you can. Leave the plugs out over night and use air to dry them out also. You need to get the compression back. Possible a little oil to help seal, (use as last resort).
put back rocker and try starting car up and still bogged and did the same thing.........the question is do you guys think something is engine is messed up? it turns on but boggs like crazy and dies..........any help is appreciated........thanks.......
Originally Posted by DynoFlash
You can send me the ecu and I will give you a temp base file to use before your tune - PM me for details
still trying to make sure car runs Al..........thanks totally appreiate it man....
I would suggest sending the ecu to Al with a list of your mods.
Also put the stock Fuel rail back on with the stock injectors. Are you getting spark to all 4?
yes getting spark to all four........
first and second has no compression right now.......still turns over but bogs and dies.....willl it make a difference if i send it to Al.........is the engine messed up?
