584whp/527wtq Stock ECU!
Old Jul 13, 2006 | 12:27 AM
Smogrunner's Avatar
Mods are:
Stock ECU tuned by Alfred at Tuning Technologies with ECUFlash: No AEM, No Speed Density, no piggy back.
Stock head
Stock intake manifold
Stock throttle body
Stock ignition
Stock MAF
HKS 272 cams
Vishnu cam gears set at 0 (stock)
AMS 2.3 without balance shafts
AMS 35R kit
AMS 880 injectors
Tuning Technologies affordable 700whp fuel system
Nisei Intercooler and upper IC pipe
Vishnu Signature 3 inch exhaust
C16 fuel @ about 30psi
Going to the track on Saturday AT LAST! Alfred backed it off just a tad on the last pull because I haven't raced the car yet and I want to go out and just get the feel for it. There is enough headroom to push the car to 600whp but one step at a time....
Old Jul 13, 2006 | 12:59 AM
NocturnalEVO's Avatar
sweet!
race gas?
Old Jul 13, 2006 | 01:11 AM
03evo8gsr's Avatar
thats sick man, hope to get mine tuned soon.
Old Jul 13, 2006 | 01:15 AM
fromWRXtoEVO's Avatar
Simply, shocking. WOW. Congrats!!
Hey what happened to the Malcom X avatar?, I use to love it.
Carlos
Old Jul 13, 2006 | 01:17 AM
Fourdoor's Avatar
Arn't you afraid of sucking in the honeycombs in the stock MAF sensor? That is the only issue I would have with your entire setup..... looks like you should be running some sweet times! Every time I go fast, you step right back up and get faster yourself....
Keith
PS: Update that sig with your new dyno numbers!
Old Jul 13, 2006 | 01:25 AM
Smogrunner's Avatar
Keith
We have taken several steps to keep that from happening again:
1. We moved the BOV dump much further from the MAF.
2. We scuffed the inside surface of the MAF housing and epoxy glued (the nasty stuff) the MAF screen to the wall of the MAF.
3. We super glued the little black MAF plastic piece to the front of the MAF.
4. We checked its condition repeatedly during the dynoing and after the test drives and it is still in perfect condition. We'll see how it holds up over time, but it is definitely secure enough that it isn't going to get sucked into my compressor...
Old Jul 13, 2006 | 01:34 AM
IE Evo's Avatar
Congrats Tom! I guess I will be going to Fontucky to hang with u and Alfred. Hope the weather cooperates a lil this weekend. Low 11s would be nice and the Heat that only Satin could appreciate will likely keep u in the 11s.
Old Jul 13, 2006 | 01:53 AM
Ang Wen Yan's Avatar
Congrats Smoggy!!May I have your dynojet run file??
Old Jul 13, 2006 | 02:27 AM
RREvo's Avatar
Congrats on your numbers, one question I have to ask you what hapend to the XEDE why did you change it?
Old Jul 13, 2006 | 04:05 AM
4ringturncoat's Avatar
Do you have a boost log? Looks like it's got some pretty good boost by 4500rpm. Nice numbers
Old Jul 13, 2006 | 04:21 AM
Torre from Va.'s Avatar
That's pretty cool, because AEM is F**king killing me !!
Old Jul 13, 2006 | 04:22 AM
A Robinson.'s Avatar
Nice numbers man keep up the good work.
Old Jul 13, 2006 | 06:02 AM
anjapower's Avatar
Wow, good results!
Why did you dump the xede?
Old Jul 13, 2006 | 06:14 AM
12mnkys's Avatar
smogrunner,
with the stock ecu and the stroker did you have any trouble with the factory knock sensor?? I have a 2.4 stroker w/ cosworth head and cant keep the timing from getting pulled out of the bottom end. I know with the cosworh head that i am flowing alot more air so we were thinking that the stock maf was insufficient. what hertz are you reading from 0-3k??
Old Jul 13, 2006 | 06:28 AM
ibanez_926's Avatar
nice smoggy!
good thing you got them adjustable cam gears
