is it possible
Old Jul 13, 2006 | 06:18 AM
dustin03's Avatar
is it possible
so I would like to make 400 whp. I will be doing a 20g 9 5 setup. I would like to do this wihout any major head work. What do you guy think I will need to make my goal or eve go over that goal. I am not sure how I feel about alki or meth injection. But maybe you can give me some insight on all of this. Thanks, Dustin
Old Jul 13, 2006 | 06:24 AM
ibanez_926's Avatar
sigh, all the bolt on's, big cams and alchy injection
please research
Old Jul 13, 2006 | 06:26 AM
dustin03's Avatar
wow........ ok well here it is I have intake lower ic pipe 3 in turbo back 680 injectors walbro fuel pump and mail in flash.
Old Jul 13, 2006 | 07:54 AM
Warrtalon's Avatar
that will be good for 300-330whp maybe. As has been said 1000 times or more, you'll need exactly what Ibanez said:
- Cams
- Alky or Race Gas
- Custom tune
You certainly didn't need those injectors.
Old Jul 13, 2006 | 07:57 AM
dustin03's Avatar
but acording to BR they told me I wouldn eed to up my injectors from the stock ones. Also Warrtalon if I put a set of 272 and a custom flash would that get me close or should I through the hole idea a try to go 50 trim.
Old Jul 13, 2006 | 08:41 AM
Warrtalon's Avatar
No, that still wouldn't be too close to 400whp. You need cams, alky, and a custom flash.
Old Jul 13, 2006 | 08:46 AM
Sharkbite2000's Avatar
Alk Injection is a Must to acheive those numbers.
Old Jul 13, 2006 | 08:49 AM
dustin03's Avatar
but what are the danger's that I will be taking if I use alky? What if I run Race gas?
So what you are saying there is no way unless I use alky?
Old Jul 13, 2006 | 08:53 AM
Warrtalon's Avatar
What I'm saying is that you need something to allow you to run big boost to hit 400whp, which means race gas or alky. Running race gas 24/7 is not feasible, thus the alky recommendation. If you dont knoe the risks, then I dont suggest using alky, nor do I suggest worrying about 400who on a stockish turbo.
Old Jul 13, 2006 | 08:58 AM
dustin03's Avatar
well I thought that is what the forms were for. If you don't know there are people out there to help you along. That is why I asked the question now if you don't want to answer it that is fine. I know I will need to run high boost that is where these turbo do there best. I wouldlike to make the 400whp for the track. Daily driving it is nice to have 350 + to the wheels. That is also why I asked so I just bump up to a 50 trim or 3076.
Dustin Warthold
Mitsubishi TC-SST Discussion
Jul 7, 2017 07:32 AM
devildevil
20
Nov 14, 2010 11:55 AM
dustin03
Northwest Region
Apr 27, 2008 02:19 PM
dustin03
Aug 29, 2006 09:14 AM
