Hey everyone,
My car is making the "blow off" sound even though I have the stock BOV and the car is essentially stock (TBE, MBC). I had the same problem once before and it was one of the hoses going to the BOV that popped off. This time though, ive checked and double checked every connection I can think of through the system and it seems like everything seems fine, can't find any disconnected hoses. Any ideas?
*EDIT*
Forgot to mention, I already searched and it kept coming up with millions of threads about aftermarket BOV's and not technical problems.
*EDIT 2*
reworded some things
*EDIT*
*EDIT 2*
Quote:
stock box.Originally Posted by Danny23
what kind of intake do you have, stock box or aftermarket?
wow you mean a blow off valve makes a blow off vavle sound? thats freaking wierd man.
Quote:
Its a recirculating valve and and it dosent make the "blow of vavle sound" with the stock intake.Originally Posted by FatheroftheEVO
Quote:
Yeah it kinda is when its recirculating Originally Posted by FatheroftheEVO
Quote:
I dont have an aftermarket filter. Everything is stock.Originally Posted by Utah-evo
its because of the filter if you dont like it put the stock one back in
ya i just realized that wasent you that said that. has it always done it that is kinda wierd. i don't know what could be causing that
PROBLEM SOLVED
After my fourth time checking now I noticed one of the clamps that I couldn't see well looked loose, so I felt under the bottom and the hose was slipping off on the bottom.
