Untuned.....
Old Jul 22, 2006 | 11:52 PM
fitch's Avatar
Unhappy Untuned.....
Just installed my 50trim turbo kit... Just curious.... how is the car suppose to sound and ACT???? My car at a cold start is fine but as it warms up.... it idols funny.... Jumping to 0 to -10 psi... Untuned.... Sometimes shutting off.... completely... Car also dies.... Very Loopy idol.... Looked for threads about this but couldn't find any.... for my application.... I'm also thinkin and was told by my buddies, its the cams.... 272 GSC's.... Need confermation on this.... Help me out....
Old Jul 23, 2006 | 12:05 AM
KartaRailed's Avatar
..... its because its untuned, now if it still does it after you get it tuned, come back and speak with someone knowledgable.
Old Jul 23, 2006 | 09:05 AM
Nad1370's Avatar
Installing a turbo or GSC 272's won't give you these problems even untuned at idle.
I'd check for intercooler hoses that are not properly installed. Cams for timing. Might have a damage MAF during the install. ect...
Did you start having problems after the turbo install or cams ?
Old Jul 23, 2006 | 09:17 AM
Genesis8's Avatar
Fitch drives like crap after the turbo installation. I drove his car and the boost gauge is on zero when you drive it .(The boost gauge does work). I was like Damn there is something wrong with it. But his car is flash(before his turbo kit was put on). That might be it???
Old Jul 24, 2006 | 12:26 AM
fitch's Avatar
I have them both....
Old Jul 24, 2006 | 12:27 AM
fitch's Avatar
Thumbs up
It does that sometime.... I don't know why.... But it'll work after a little drive.... And its the car that drives bad.... Not me.... HAHAHAHAHAHA
Old Jul 24, 2006 | 12:52 AM
feautoevo's Avatar
seriously just check the intercooler pipes, you have one not connected
Old Jul 24, 2006 | 10:10 AM
fitch's Avatar
checked them all, but will be checken anyways.... thanks....
Old Jul 24, 2006 | 11:37 AM
Creamo3's Avatar
Did you do the cams the same time you did the turbo install? A larger turbo will not affect your previous tune when idling or off boost. I would go back and check for leaks and make sure everything is plugged back in ie. maf sensor.
Old Jul 24, 2006 | 11:48 AM
MrMejia's Avatar
usually the one who works on it knows best. mainly the owner. so my guess is you right?
Old Jul 24, 2006 | 12:18 PM
EvO6-RS2's Avatar
Who installed the cams? Maybe they're not lined up properly...re-check cam install...this often affects vacuum reading, idling....giving the symptoms you describe. (that's if the cams were installed at the same time...as the turbo)
Also, makesure turbo is properly bolted to manifold & turbo manifold properly bolted to head.
My friend installed a GT35r and his car idles really low sometimes & stalls...but still boost to 18psi & makes power no problem. But we haven't figure out why it idles so low as yet.
Hope that helps.
Old Jul 24, 2006 | 12:22 PM
Warrtalon's Avatar
It's not the cams unless they're off a tooth (or more). Don't you have huge injectors without being tuned for them? I would think that would cause problems, but not sure if what you're experiencing is normal at all.
Old Jul 24, 2006 | 08:34 PM
fitch's Avatar
No, i installed the cams about a year ago... Beyond Redline in Green Bay Wi.... Did my install.... Nice shop.... Anyways, i just installed the turbo about last wkend.... Basicly doing what my cams did when i was untuned.... But the idle is sorta worse.... Unplugged everything and reinstalled.... Code 003 sometimes comes on.... Esspecially with the loopy idle.... checken for leaks tonite.... installing my alky kit and fuel rail.... injectors later.....
Old Jul 24, 2006 | 08:36 PM
fitch's Avatar
I have the injectors BUT did not install... waiting until the tune.... and so is Elf....
Old Jul 24, 2006 | 08:37 PM
Warrtalon's Avatar
Gotcha. I wouldn't recommend trying to boost then, since you won't have enough fuel supply, but that unfortunately doesn't explain your strange idle behavior. It seems like it would be something vaccuum related like a big IC leak, unplugged MAF, or some disconnected hose that was missed.
