Random/Multiple misfire
My 06 does the same thing. Random stumble at idle. Threw a code the other day but just reset the ecu, didnt pull the code. I put in some 100 a day or so after that, and it hasnt been idle'ing NEAR as rough. Theres still a very slight vibration, but not like it was doing where it felt like it was going to stall. Wish I could figure out what it is too, my car only has 5000 miles on it.
What do you mean? If someone was smart enough to just get the car scanned there wouldn't even be a problem. There could be a million things wrong, thats why there is an SES light.
What are you talking about? I have gotten my car scanned, I mentioned it in the beginning of the thread. P0300
Yeah I'm a dumb ***. P0300 TSB's should have fixed this problem. I would ask the dealership for an explanation (and possibly a new ECU).
Alot of evo owner use an after market air filter that is preoiled. This oil gets all over the maf sensor and cause all kinds of problems.
Try spraying the sensor off with MAF cleaner. It can be purchased at Pep boys, Autozone. The can is grey and has red writing. It's specifically for Maf sensors. I keep mine nice and clean. It makes a big difference.
Could also have an O2 going bad. The idle problem sounds like a vacuum leak. Check your intake manifold gasket....with the car running, spray some carb cleaner around the intake manifold, places where it could be leaking. Listen for the idle to change....if it does, pay attention to where your spraying the carb spray.
ey buddy i have the same ****en problem....and it also started after i installed my megan catback...but as of right now my car is running fine....i also have a recirc. BOV which makes idle a bittch....but as of now im fine car idles bad at times and it idles good i dont really know but its also pissing me off, so as of right now i think im just gunna kick the **** out of the car and see what happens! but if u find out anything hollar this way alrite!
