Intakes: Buschur vs. HKS RS
Originally Posted by richie11
there tested the green filter, but i have the hks racing suction intake with the yellow filter, is it the same
Originally Posted by vboy425
This thread makes no sense. Looks the title of this thread it say "Buschur vs HKS" than in the post he mention HKS it makes more power than the Buschur but the AFR 12.8 vs 11.8 WTF ? if you were running that lean I hope you do make more power. Than towards the end of his post he said "this is just showing you can't tune all intake the same". So did the hks make more power than the buschur all not? since they both running almost the same AFR now.?? also is this thread about who's better? or tuning tips?
Originally Posted by KOEvo
Search, the HKS RS intake is the most detrimental intake available. A LOT of people use it because it makes good power, but your just as good off running no filter at all. That is why your BOV got louder etc. The filter on those let EVERYTHING through.
i have an hks intake with a knn filter... the sound is the same as when it was with the hks filter. wow... that just totally indicates anything.
Originally Posted by elhalisf
ok, lol, thanx for making me feel good. The point of this thread was to show the differences needed to tune the intakes. I did not make a big point as to which intake makes more power since i did not bring numbers of dyno's and such. But with the change in the AFR numbers, its obvious that the HKS RS sucks in more air.
That change of AFR does NOT mean the HKS intake sucks in more air. It only means that the HKS intake throws the MAF readings off in a manner that makes your tune dangerously lean on pump gas compared to your BR intake. People are going to be justifiably jumping all over you if you keep shooting at the hip with such assumptions.
Originally Posted by Roberto
A better title would have made your "point of this thread" far more clear.
Originally Posted by trinydex
are you sure that it throws it off in such a way? do you have a map sensor mounted giving you the absolute manifold pressure and hte corresponding comparison between the two? i just wanna beg the question, cuz otherwise it's hearsay.
That is as far as I'm willing to go into this on here. You can believe what I say, or be convinced that the HKS RS intake is actually significantly outflowing a BR intake setup.
Yes I'm certain, and I don't need a map sensor in the plenum to tell me that, when in fact it would do little to tell me that. The intake switch obviously does alter the accuracy of the maf sensor from what his tune was for, and it starts to count less air than is actually going into the engine, hence the significantly leaner afr. Please don't confuse that leaner afr with the HKS RS piping and intake actually flowing that much more air, because that's not happening. A speed density system with static load maps based on a correlation of map and rpm would tend to act that way with a vastly superior intake switch, whereas a mas system actually does *should* just count more air mass, and add the appropriate fuel for the calculated load. That's the beauty of the mass air system over speed density. The difference (some people say problem) in the Evo from many other mas systems on performance cars, is that it is KVP instead of hot-wire (more common), the sensor is very close to the filter intake, and differences in airflow turbulence and pressure waves can alter the interaction in the formed vortices and the pressure sensing of said vortices. This can alter how this type of mas counts air, and that is the underlying reason why most tuners recommend you specifically tune the Evo for different types of aftermarket intakes. Hotwire mas systems just tend to be less sensitive to intake changes than KVP setups, at least on the LS-1s and Mustangs they were.
if mas "counts less air" with the hks rs, then why are my low/mid/high fuel trims still at 100% and i idle at 14.7 afr. your not making any sense with your explanation.
If you do not want to believe (or do not understand) my explanation, then that is fine with me and I'll spend no additional labor explaining this stuff to you. Believe whatever you want to and go out and murder all those vastly inferior BR intake equipped Evos out there with your HKS superflowing intake.
I don't want to sound like an *** but you mentioned twice that" the dyno tells a different history however you did not provided any dyno numbers.. this is what you said:
1) The setup was great and my butt dyno told me it made good power over the stock intake
2) again, the butt dyno tells me there is more power
You also talk about the AFR ratios but you provide zero dyno numbers.. We already know that different intakes causes different AFR due to different reading on the MAF(velocity,flow etc) but we were hoping you were going to provide more concrete evidence.
The HKS is well known on this forum for being very"transparent", it is extremelly pourous and it allows tons of air to go through, unfortunately for people that live in dusty places like AZ we have a lot of trouble, it lets all the dust go through.
Is there any dyno numbers you could provide us?. I personally use a Buschur cone and it works very well, it makes the stock BOV to sound loud.
As far is the HKS air pipe, in my opinion is one of the best. You should do what someone suggested, HKS pipe plus Blitz filter, I bet that is the right combo for performance.
Carlos
Carlos
Carlos
Carlos
all i wanted to point out is that you can't tune both intakes the same. but i did come to a logical conclusion that the hks rs one sucks in more air because of the leaner afr's i was getting.
I'd find it hard to believe all of your fuel trims are normal with your actual afr so far off from any reasonable target in a competent tune. If your car was tuned for the intake that is on there, the trims should be normal only when you are consistently close to your afr targets. Your reported situation makes far less sense than my explanation of how our mas can be affected by intakes. What are you using to view the trims with, and are you sure it is accurate? Also, if you think your idle afr is completely dependent on what that maf sensor is seeing at such a low volume of intake air (like at idle), you are mistaken.
yes, fuel trims remain the same. i hope that you actually understand what fuel trims are. i am using evoscan to log my fuel trims. my whole point of mentioning the fuel trims was that when the mas "counts less air" then i should be running leaner and my fuel trims will be over 100%.
I'll leave it at this... If you actually think your HKS intake is allowing approximately 40 to 49 more cfm over a BR intake setup, you are just mistaken. That's WAY too much for a similar intake setup, and about what it would take to lean your afrs out that much on a static tune based upon a completely unaltered mas curve. It’s just not happening. If it were, we’d be deluged with dyno threads expounding on the consistently measurable gains that intake provides. I’m not seeing even a hint of that trend anywhere in the Evo community.
Believe what you want to.
