Intakes: Buschur vs. HKS RS
Old Jul 27, 2006 | 11:01 PM
  #31
vboy425's Avatar
i have come to conclusion that what "elhalisf" trying to say in this thread he have posted is that "He loves the HKS RS". that's the only thing make sense sofar. The End Beside elhalisf can you elaborate on what do you mean by saying people don't understand the purpose of this thread?? i'm still confuse?
Old Jul 27, 2006 | 11:05 PM
  #32
elhalisf's Avatar
Originally Posted by Roberto
You do know that Evoscan fuel trim reporting accuracy has already been publicly called into question right? I suggest you go and read the appropriate forums on this, and not trust what it is reporting to you for fuel trims quite yet. You already stated that you were running leaner right? Thats enough information right there without even getting into whether the fuel trims you think you are seeing are real. From what you reported about your afr leaning out by an entire point with nothing but an intake change (to what is well known as a similar flowing intake system), It’s quite obvious that one of two things is happening. Either that intake is allowing for far more additional air flow than any common intake swap known on the Evo, or your mas curve has been affected by the intake change.
I'll leave it at this... If you actually think your HKS intake is allowing approximately 40 to 49 more cfm over a BR intake setup, you are just mistaken. That's WAY too much for a similar intake setup, and about what it would take to lean your afrs out that much on a static tune based upon a completely unaltered mas curve. It’s just not happening. If it were, we’d be deluged with dyno threads expounding on the consistently measurable gains that intake provides. I’m not seeing even a hint of that trend anywhere in the Evo community.
Believe what you want to.
yes, i have read that malibujack states that he sees different fuel trims with his scanner. however, with the zeitronix, i can see my afr's in real time. wheather its at idle or cruising, it sticks between 14.7-14.8. that tells me right there that the evoscan fuel trims are correct.
moreover, fuel trims should be completley unaffected by the type of intake. i wish that you have taken some time to understand what fuel trims are before arguing again. fuel trims are based on closed loop operation, so no matter how much air your sucking in, no matter how efficient your filter is, your fuel trims will not change. the ecu reads off the O2 sensor in closed loop, so it always readjusts to get 14.7.
the leaner afr's i got are based on the open loop operation at WOT, which are read off a fuel table.
Old Jul 27, 2006 | 11:10 PM
  #33
elhalisf's Avatar
you and others, are getting the impression that i created this thread to show people how much better the hks RS is over the buschur filter. that was not the statement i was making.
all i wanted to show is that different intakes require different tunes. obviously the hks rs needs much more fuel at WOT than the buschur. i came to the logical conclusion that the hks rs sucks in more air.
and yes, i like the hks rs. I decided to stick with it because it made my bov louder. the end
Old Jul 27, 2006 | 11:18 PM
  #34
vboy425's Avatar
i'm not trying to pick on you at all bro, it's just make nosense on anytihn you are saying.
here read what you posted again, i also highlited the key factor.
Well, up until a couple of weeks ago, I had the buschur filter with the intake pipe. The setup was great and my butt dyno told me it made good power over the stock intake. At that time, I tuned my ecu to 11.8 (dropping by redline) AFR using a zeitronix wideband. Then a couple of weeks ago, I saw this smoking deal on an hks rs intake setup that I was gonna buy to resell. But I thought, what the hey, let me try it on the car. I put it on the car, and, again, the butt dyno tells me there is more power. At that time, I didn’t have the wideband hooked up, so I used the evo scan to datalog knock. No major knock showed up. It also made my 1G BOV sound much louder, so I decided to keep it. Well, I finally hooked up the wideband again, and guess what I see? My AFR hits a max of 12.8 averaging at around 12.5!!! I had to richen up my octane map by about 1 point in every high load table, and now I finally got it down to 11.8 dropping to 11.2 towards redline. This is just to show that you can’t tune all intakes the same.
Old Jul 27, 2006 | 11:30 PM
  #35
supersupra's Avatar
I like the HKS RS.
I have an e-mail flash and it has been difficult to tune since a/f have been 12's. I had to enrich the mixture 3 times. I guess the tuner did not take into account the HKS RS, which obviously flows better. And oh yeah, it sounds awesome.
Old Jul 27, 2006 | 11:32 PM
  #36
vboy425's Avatar
Originally Posted by supersupra
I like the HKS.
see here's an example of a good thread it's simple/clear/honest and straight to the point
Old Jul 27, 2006 | 11:33 PM
  #37
elhalisf's Avatar
key factor in my first post
"This is just to show that you can’t tune all intakes the same. "
Old Jul 27, 2006 | 11:36 PM
  #38
vboy425's Avatar
so why is your title like it that ?? and why did you say HKS RS feel much power over the buschur?? honestly i gave up, i don't want you to feel ike i'm picking on you.
Old Jul 27, 2006 | 11:54 PM
  #39
Roberto's Avatar
I fully know well how fuel trims work, so don't bother with your rudimentary explanations. Please try to refrain from such insults as they don't help make your case. Everything I've said still holds true, and the fact that your HKS is not dramatically outflowing the BR intake system still holds true. Once again, superior flow of that intake is NOT responsible for your significantly leaner afr under wot. AsEvom-recognized experts chime in on this, maybe you'll finally concede, but I'm finished trying to convince you of the obvious.
Old Jul 27, 2006 | 11:57 PM
  #40
elhalisf's Avatar
i am sorry if you regarded my comments as insults. that was not my intention.
Old Jul 28, 2006 | 08:20 AM
  #41
supersupra's Avatar
Duffus, I used it to make a pointer/placer and continue latter. And yes, it was honest and to the point
tiffer148
Oct 31, 2011 09:16 PM
scott88vr6
89
Feb 13, 2011 11:48 AM
storm_trooper
19
Jul 14, 2010 10:23 AM
TakaseEVOIXSE
16
Mar 20, 2009 11:39 AM
nj1266
Oct 13, 2007 04:09 AM
