fuel starvation prevention
Old Aug 8, 2006 | 11:01 PM
boostless's Avatar
I was watching a tuning video and the shop's car had a smaller pressurized tank in the trunk (looks a little bigger than a catch can). It supplies a constant fuel supply when the car is under hard cornering while low on fuel.
Does anyone know what it's called and where it can be ordered? A friend needs one for off road use
Old Aug 8, 2006 | 11:04 PM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
yeppers...its a surge tank ...i have a custom fuel system in my evo that utilizes a surge tank...will get pics up shortly....contact matt at slickmotorsports he makes all kinds of different stuff like that....216-361-1150 and tell him evodave sent ya...if he is busy and doesn't answer you can leave a message with your info and he will call ya back.
Dave
Old Aug 9, 2006 | 03:01 AM
trinydex's Avatar
be wary, surge tank kits that use stainless braided lines will exude gasoline vapors. they don't leak a drop but the vapors will kill you or give you cancer... which kills you.
Old Aug 9, 2006 | 06:50 AM
M00kiE's Avatar
if you're vin diesel, you've got gasoline running through your veins... so breathing a little vapor shouldn't be too bad...
Old Aug 9, 2006 | 07:43 PM
boostless's Avatar
thanks for the replies.... What is the extent of the installation? It seems pretty simple but im not sure whether you can use it with a stock fuel tank or fuel cell. (evodave says his fuel sys. is custom)
Old Aug 10, 2006 | 12:30 AM
trinydex's Avatar
if you ahve a fuel cell you don't need a surge tank. the cell ensures (at least it should) that you will not start fuel.
a surge tank is for running the stock tank. you have to mount it near the tank, run lines in the tank out hte tank and back in the tank. with some pumps inbetween.
Old Aug 10, 2006 | 10:37 AM
evodave's Avatar
i will have pics up shortly!!
Old Aug 10, 2006 | 12:36 PM
JDMevoBOOST's Avatar
interested to take a look at ur setup dave
Old Aug 13, 2006 | 04:29 PM
evodave's Avatar
the system can be installed easier then a fuel cell setup for sure.
