Need Tune after raising the Boost?
Old Aug 9, 2006 | 02:32 AM
dxbevo9's Avatar
hi guys...
the title says it all..
do i need to tune after i raise the boost?
"yes..i tried searching ... but couldnt find anything..."
thanks in advance
Old Aug 9, 2006 | 02:50 AM
smoothmarine187's Avatar
Veteran: Marine Corp
You will not need a tune, but I hope you have a full exhaust otherwise you will have to much back pressure if your trying to raise the boost on your stock exhaust.
Old Aug 9, 2006 | 05:36 AM
3SgteGuru's Avatar
If you just raised the boost level, you can get away withot one. But if you got other mods like exhaust and intake and ic pipping i would top it off with a Nice custom tune. (not mail in) go to a shop w/ a dyno and get it tuned
Old Aug 9, 2006 | 07:01 AM
dxbevo9's Avatar
yes i do have a TBE and a drop in intake...however...due to some shipping delay on the boost controller...my tune is schedulled before the expected date of arrival of the boost control..
so you guys are suggesting i could get away with it..ha?
thanks for the replys...
weird...i was waiting for out beloved Warr. to reply....
Warr...would you please share your opinion and experience.
thanks
Respect
Old Aug 9, 2006 | 07:31 AM
Warrtalon's Avatar
You aren't supposed to raise boost without a tune, but your original question didn't give all the details. What you're saying here is that you're getting tuned before the MBC arrives. If the tuner knows how to use the EcuTek software, which is what you said you're getting flashed with, then the boost resulting from the EcuTek shouldn't be too far off from the boost you'll run daily on pump gas with the MBC. So, I think you will be ok, but you should let your tuner know that you'll be running an MBC AFTER the tune and shoudl tell him the exact psi you plan to run on pump gas daily.
Old Aug 9, 2006 | 11:03 PM
dxbevo9's Avatar
Thanks Warr...
Respect
