Propeller Shaft boot broken :(
Old Aug 18, 2006 | 09:35 AM
ny-quiL's Avatar
I was changing my oil last night and saw that the boot on the rear portion of the propeller shaft was leaking. On inspection i saw two cracks . Im wondering if anyone has replaced this part before or ran into this problem. Currently I am trying to get the LJ Bootkit - first call into the dealer they said they couldnt get just the boot and I needed to buy a 200$~ish kit to replace it. After looking in the shop manual i belive they qouted me for the entire joint kit and not just the boot kit see image below -
Does anyone have a part number for the circled LJ Boot kit ?
Thanks
Old Aug 18, 2006 | 12:04 PM
Dr. Fob's Avatar
Chris, it's time for you to turn to the dark side and get an STI.
Old Aug 18, 2006 | 12:07 PM
MBaran's Avatar
MB837572 Is the part in CAPS. Its called BOOT KIT, PROPELLER S LJ
The entire joint kit is PN MB837239
Old Aug 18, 2006 | 12:16 PM
idriveanevo's Avatar
but then he would have a BIGGER problem.....
Old Aug 18, 2006 | 12:19 PM
MBaran's Avatar
I don't think theres a part number for the STI Delete kit. haha
Old Aug 18, 2006 | 12:32 PM
ny-quiL's Avatar
Thanks a ton!
Old Sep 8, 2006 | 09:29 AM
mitsuorder's Avatar
This happened on my car back in '03 with just about 15k on the odometer. It was the LJ joint #3 according to the dealership. Back then they only offered the replacement kit in it's entirety. Thank goodness the dealership was cool back then. Thanks for pointing out the part number for the boot itself. Did you have a spray pattern of packing grease under the car?
barneyb
28
May 22, 2021 01:16 PM
Johnr352
11
Oct 15, 2014 07:59 AM
oftheheavens
Oct 15, 2010 09:21 PM
tsi90awd
Jul 16, 2010 01:30 PM
Zeus
Nov 1, 2009 03:22 PM
