Car bucks when I punch it......
Old Aug 20, 2006 | 10:03 PM
fareastkorean's Avatar
Does anybody know why my car started to buck or backfire while I am on the gas. Ever since I checked my gas pump a few months ago the car started bucking. But then my friend help me take out the gas pump again and nothing was wrong. Whenever I punch it in any gear and I press hard on the gas, the car will accelerate but it will buck while doing so. I haven't checked my sparkplugs in a while, was wondering if my plugs could be bad, or my gas pump might be going bad?? Not sure, I do have a dynoflash, or was wondering if I am perhaps pulling timing.
Old Aug 20, 2006 | 10:15 PM
badhabit90's Avatar
check your intake piping to and from the FMIC. you may have a leak.
Old Aug 21, 2006 | 12:15 AM
heavens turbo's Avatar
that or your plugs could be fouled out.........
Old Aug 21, 2006 | 12:24 AM
by the way, what plugs would you guys recommend and gap size??
Old Aug 21, 2006 | 12:47 AM
4TUN8's Avatar
br8es gap them to .024
Old Aug 21, 2006 | 05:26 AM
Jewish Santa's Avatar
My car did the same thing until I changed the Plugs
Old Aug 21, 2006 | 05:34 AM
4Gsixty3's Avatar
How often do u guys change yr plugs?
Old Aug 21, 2006 | 07:55 AM
gsrboi80's Avatar
I change my plugs every 5k. For the original poster I would stick with plugs in the stock 7 heat rang since your mods really dont warrant you using colder plugs.
BPR7ES is what I use gapped to .026. Unlike 4tun8 you dont need colder plugs yet. With the copper plugs youll have to change them more often.
Old Aug 21, 2006 | 08:49 AM
thanks everybody 8- )
Old Aug 21, 2006 | 09:04 AM
Ultimateone's Avatar
Did you hit fuel cut?
Old Aug 21, 2006 | 09:16 AM
4cefed's Avatar
plugs should do the trick, I had the same problem
Old Aug 21, 2006 | 09:24 AM
4TUN8's Avatar
I used BR8ES with similar mods to him, that's why I said that, and they worked great.
/shrug do what you want.
Old Aug 21, 2006 | 02:41 PM
gsrboi80's Avatar
Yea I tried them in my VIII from info I got from a shop. The 7's seem to run a little better in my car. I also have about the same mods as him. I just posted cause I thought you were saying they are what you run with your 20G. And since hes on a stock turbo and only 21 psi I figured he dosent need anything colder than 7's
Old Aug 21, 2006 | 04:39 PM
RalliArtEvoVIII's Avatar
damn korean you look like a old man
Old Aug 21, 2006 | 04:41 PM
deegaw11's Avatar
could it be your clutch by any chance?
