What would net me more performance gains?
Old Aug 24, 2006 | 09:23 AM
Ultimateone's Avatar
A test pipe something like the Ultimate Racing TP or an LICP like Horsepower freaks or Buschur?
Im lost, and how loud does a TP usually make a turbo back exhaust?
Old Aug 24, 2006 | 09:25 AM
KOEvo's Avatar
As far as a dyno goes, the TP will net the most gains (almost 10 whp not tuned, shown by recent SBR findings), but as far as feel, and the butt dyno is concerned, the LICP will give the most gains. It's a stretch to say you gained WHP based off a dyno when testing the licp, they are just negligable.
Old Aug 24, 2006 | 09:26 AM
gregfromblur's Avatar
I think you're gonna get more gain off the Test pipe, on that fact that its taking one of the biggest restrictions out of the flow path of your vehicle.
I'd go for the test pipe. The noise will increas a little, but if your just putting the test pipe on your stock DP, and Cat back, then the sound gain will be minimal. may here a bit more of the turbo spooling of your outside of the vehicle.
The lower IC pipe will give you a slight gain, but i think it helps more with response, as the stock IC hoses can expannd under boost.
just my .02
Rnm's Avatar
Rnm
A test pipe will yield more performance gains, and yes, it will typically make your exhaust louder depending on your catback. I'm catless with a Greddy Evo2 exhaust and its still quiet.
Old Aug 24, 2006 | 09:29 AM
Hmm my Tanabe is not too bad cruising or wot, Im just stumped at what too get, some say teh LICP quickens spool but the 10+whp bump from the TP is nice.
Old Aug 24, 2006 | 09:36 AM
I say go for the Test pipe. take full advantage of that TBE
Old Aug 24, 2006 | 09:37 AM
saiyanzzrage's Avatar
testpipe
Old Aug 24, 2006 | 10:04 AM
Bom's Evo's Avatar
cheap enuf to do both.
Old Aug 24, 2006 | 08:43 PM
91TSiGuy's Avatar
Definitely the test pipe. Sure the LICP will help spool up and getting the air into the motor but you'll be stuck with the extra back pressure still from the cat. Like people say, engines are comparable to pumps. It injests air, makes power through combustion, and then exhales. Having the last portion of that cycle at a disadvantage does you no good because you want the gases out as fast and easy as possible.
Old Aug 25, 2006 | 12:29 AM
Ang Wen Yan's Avatar
Tp Ftw
Superchargedk20
Sep 18, 2016 07:56 AM
isiz
Mar 25, 2016 09:09 AM
isiz
Nov 3, 2015 10:28 PM
marcpaelo
Apr 10, 2013 07:54 PM
bbak11010
Apr 20, 2011 01:26 PM
