engine / turbo, something is wrong
Old Aug 26, 2006 | 04:45 PM
nothere's Avatar
Can't boost above 1/2 psi. Slight whriling noise that matches revs. Ran great at a lapping event, stopped the car, started it an hour later and had no boost.
Tried leak test, holds, no leaks, held air pressure through to the oil filler cap.
(btw) the intake side catch can had water, seems a little odd(?)
Checked the cat, not clogged at all.
The intake side of the turbo looks fine, spins freely, has the slightest lateral play.
The actuator rod is connected and tight, spring seems to be normal.
When I try to accelerate the boost tries to build but rises to about 1/2 psi or so then slips back down. Burns no oil.
History; Had the head replaced recently, Have an ebc, standalone, aftermarket filter.
Thge car recently had a coolant failure that meant replacing the head.
Old Aug 26, 2006 | 05:06 PM
scottatyamaha's Avatar
Broken wastegate?
Old Aug 26, 2006 | 05:37 PM
520hpsti's Avatar
ya seems like hte wastegate might be stuck open.
Old Aug 26, 2006 | 05:41 PM
nothere's Avatar
is the flapper being broken somewhat common?
the actuator rod is holding the lever in the closed possition.
Old Aug 26, 2006 | 05:45 PM
520hpsti's Avatar
hmm i duno i have a EWG and im sure thats why icant boost right now is because mine is stuck open.
Old Aug 26, 2006 | 07:15 PM
sparky's Avatar
[QUOTE][/QUOTE]
What's an EWG? I don't wanna guess, huh...
Old Aug 26, 2006 | 07:53 PM
TeStUdO's Avatar
Originally Posted by sparky
[QUOTE]
What's an EWG? I don't wanna guess, huh... [/QUOTE]
external wastegate
Old Aug 26, 2006 | 08:22 PM
nothere's Avatar
I think the last time I checked for leaks I used to much pressure.
Now the car has the James Bond smoke screen. Before there was no smoke at all.
Old Aug 27, 2006 | 09:05 AM
nothere's Avatar
could some one explain to me what is happening?
I evidently pushed oil into the hot side of the turbo. I have heard blowing smoke is a sign of a dead turbo, is that because the shaft housing is to loose and the oil is getting through there?
In my case it seems odd that before pressurizing the system there was no smoke.
cerealkeller
Jul 18, 2016 08:35 AM
kmcconn9
24
Oct 5, 2009 03:43 PM
Tuner@Swift
Aug 6, 2008 05:38 PM
Kmac
Jun 14, 2008 05:24 PM
yikez
14
May 12, 2008 12:30 PM
