CEL Fix / O2 Simulator on IX
Old Aug 27, 2006 | 05:13 AM
SuperStreet2K6's Avatar
Will a mechanical fix work on the EVO IX?
Old Aug 27, 2006 | 09:46 AM
BoOsTinGEVO190's Avatar
the perrin should work man i installed it on my 8 ground the the black wire to the car it self mayeb you have a loose connection somewhere thats why its bringing the cel back?
Old Aug 27, 2006 | 10:30 AM
revvin9k's Avatar
Dont see why it would'nt fit on an Evo 9. I've had this fix since I installed my AMS TBE w/ test pipe, never had a problem.
Old Aug 27, 2006 | 12:36 PM
I used the mechanical CEL fix just now and I haven't set any codes. Any just FYI, the Perrin O2 Sim doesn't seem to work on the IX.
Old Aug 27, 2006 | 12:38 PM
revvin9k's Avatar
Old Aug 27, 2006 | 12:48 PM
tony_b's Avatar
Antifoulers don't work on my IX. After driving on the highway at 85-90mph for more than an hour or so, it'll go off but as soon as it idles for a few min., it comes back on.
The Perrin o2 sim was my last hope and now I hear those don't work either.
I may try to drill a small hole straight through the antifoulers where the sensor is to let a little more fresh air in.
Old Aug 27, 2006 | 04:12 PM
idriveanevo's Avatar
try drilling it and if no luck double them and it will work, it getting to hot and throwing the cel
Old Aug 27, 2006 | 04:18 PM
EFIxMR's Avatar
we run mechancial o2 fixes on our evo9's. ours are prefit no drilling ect. give us a call if you need one.
Old Aug 27, 2006 | 04:24 PM
Rnm's Avatar
Rnm
Just get a Ultimate Racing test pipe as it has a built in o2 fix.
Old Aug 27, 2006 | 05:15 PM
tony_b's Avatar
I'm already using 2. Also, I'm not sure what brand tp I have but there's only a tiny hole inside where the bung is. I didn't even think I needed a fix but 2 miles later, light came on. I got some anti-foulers, drilled one out and threaded into the other and put that in the bung, same ****...
Also, the light is on but the DTC is not showing up in EvoScan.
Old Aug 27, 2006 | 05:17 PM
I hope mine doesn't come back on... It hasn't so far thought...
Old Aug 27, 2006 | 05:24 PM
555R's Avatar
the antifoulers work great on my IX
5000 miles and never CEL
no perrin CEL fix either
I have a spare if you want to buy it
I figure $15 shipped
if you want it
Old Aug 27, 2006 | 05:52 PM
EFIxMR's Avatar
EVOscans DTC works horribly. get a regular obd2 code grabber.
Old Aug 27, 2006 | 05:57 PM
maybe your sensor is bad...... foulers should work with a good sensor
Old Aug 27, 2006 | 07:47 PM
daisaw1219's Avatar
The perrin one doesnt work on Evo Ix. Use an anti fouler....its 5 bucks and it works better and no cutting or splicing of wires required.
