Help Figuring Out a Possible Problem
Old Sep 3, 2006 | 09:25 PM
Eveolicious's Avatar
Originally Posted by EvoHung
I think there are aftermarket underbraces that advertise they will clear most downpipes. Like the Tanabe's and the RMR's. Go to lancer shop or any shop and look under suspension.
Alright, cool. Thanks!
I REALLY hope this is indeed the problem.. and its not something worse, or more complicated.. I can't wait to get back home.. and jack it up to find out for sure..
Old Sep 3, 2006 | 09:32 PM
EvoHung's Avatar
I hope it is a simple problem like mines as well. Good luck!
Old Sep 3, 2006 | 09:33 PM
Thanks.
If its not the problem, I will be back posting in this thread.. haha.
Old Sep 4, 2006 | 07:54 AM
EVOlutionary's Avatar
Originally Posted by Eveolicious
Well, after peeking under my car (without having a jack) I think I've come to find out, my downpipe IS indeed hitting against my under brace. But like I said, I just peeked under there.. kinda hard to see under a lowered car... without a jack.
If this indeed the case, what is the best way to fix that rattle? What should I use to keep the two separated? (downpipe, and under brace)
Even cheaper and quicker way to fix it than buying an aftermarket brace, if this is indeed the problem, is to just put a couple thick washers between the brace and the frame. This will drop it anywhere from 1/16" to 1/2" depending on what washers you use. This is what I have done on my car. It does not affect the function or rigidity of the brace at all.
EVOlutionary
